Hello.
I am having a problem that has been already discussed in a topic below. every time i run my 3ds max, a window pops up and tells me that i must first activate this program before running it. and the only option available is "activate", the "run" option being disabled. then I get the error 110, where it informs me "a license error has occured. contact your technical support representative for assistance" and then another error, this time 20, where it informs me that "the software license check out failed"
I have to inform you that this has happened with 2011 and 2012 versions, and i cannot seems to figure it out. and I can't try the solution you had proposed in the topic i mentioned above because I can't get into the program to get my product request code.
pls, someone help. I am running out of ideas.
I have sent you my serial number, and I sincerely hope you can help me out with this, it is very frustrating.
no matter what version of 3ds max I try instaling, I get the same error. and this only happens with 3ds max, revit and civil 3d have no such errors.
hope to hear from you soon, kink of running on a deadline, so the sooner you can give me some advice, the better.
hello. I have sent you my info about 3 days ago and still no answer. can you please give me a response soon, because I really need to get a working version of 3ds max.
Hi Thelce:
I have responded to your request trhough private message. I managed to register your serial number and you shall now be abel to activate it. You may send me your request code so I may assist you in manually activating your serial number or contact our Registration and Activation Team directly through:http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Have a nice day!
Best Regards,
I know how to fix it
first,you have to open notepad and type this thing
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shell\runas]
@="Take Ownership"
"NoWorkingDirectory"=""
[HKEY_CLASSES_ROOT\*\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" && icacls \"%1\" /grant administrators:F"
[HKEY_CLASSES_ROOT\Directory\shell\runas]
@="Take Ownership"
[HKEY_CLASSES_ROOT\Directory\shell\runas\command]
@="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
"IsolatedCommand"="cmd.exe /c takeown /f \"%1\" /r /d y && icacls \"%1\" /grant administrators:F /t"
then save it name Take Ownership.reg
then click on it and click Yes
Now you can Unlock folder that have key pic on it
go to C:\ProgramData
and right click on Autodesk select Take Ownership
then refesh.Now you can see the key pic disappear
do this the same with FLEXNet Folder (same location)
Install Program again
Good luck 🙂
tryed that didn't work all way keeped giving me error talking about owership so deleted the folder and after that it works!
