Installation & Licensing
error 1067: Cannot start services
2 REPLIES 2
jeffgo888
3565 Views, 2 Replies
Hi All,
I have seen some of the replies here for above error but it does not work for me.
So I am using FME start/stop server....and its giving me above error.
I looked at log file and it says:  cannot find C:\FlexLM\license.dat
which is confusing...since i used LMTOOLS to point the "safe.lic" to another location...
any ideas why its looking at above location?
2 REPLIES 2
TravisNave
in reply to: jeffgo888
Make sure you have configured your LMTOOLS properly.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
Autodesk Forums:
dembkod
jeffgo888,
Hello. You likely have an older process that is still running on your machine with old licensing. If you are pointing to a DAT file, it is another product’s licensing or perhaps a really old Autodesk license.  Also, I do not understand when FME is. We use LMTOOLS for our licenses. If you do not have LMTOOLS installed, you need it.
You may just need to delete an older service.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
