Installation & Licensing
dias_ryan
769 Views, 5 Replies
Error 1.5,-18
Trying to install ADT 07 and Civil3d 07.
we have both licences (network) and are only able to use one program at a time. The second always returns "A valid license could not be obtained by the network license manager. Try Again"
I checked the log files and this is what i see. I have no idea what to make of it (no idea what anything in the log file means..)
ADT2007 Log>>
9:07:33 (lmgrd) pid 7772
9:07:33 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:07:33 (lmgrd) Done rereading
9:07:33 (lmgrd) FLEXnet Licensing (v10.8.0 build 18869) started on Adistj (IBM PC) (5/25/2006)
9:07:33 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
9:07:33 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:07:33 (lmgrd) World Wide Web: http://www.macrovision.com
9:07:33 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\License\ARCHDESK2007Adistj.lic
9:07:33 (lmgrd) lmgrd tcp-port 27000
9:07:33 (lmgrd) Starting vendor daemons ...
9:07:33 (lmgrd) Starting vendor daemon at port 2080
9:07:33 (lmgrd) Using vendor daemon port 2080 specified in license file
9:07:33 (lmgrd) Started adskflex (pid 7276)
9:07:33 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
9:07:33 (adskflex) Server started on Adistj for: 51500ARCHDESK_2007_0F
9:07:33 (lmgrd) adskflex using TCP-port 2080
9:33:35 (adskflex) TCP_NODELAY NOT enabled
9:43:35 (adskflex) OUT: "51500ARCHDESK_2007_0F" RBaker@RBaker-PC
9:44:59 (adskflex) IN: "51500ARCHDESK_2007_0F" RBaker@RBaker-PC
9:54:24 (adskflex) Rereading license file...
9:54:24 (lmgrd) Done rereading
9:54:24 (adskflex) Server started on Adistj for: 51500ARCHDESK_2007_0F
9:54:24 (adskflex) Updating feature 51500ARCHDESK_2007_0F
9:54:24 (adskflex) Rereading options file...
9:54:24 (adskflex) ...Finished rereading
9:54:39 (adskflex) Rereading license file...
9:54:39 (lmgrd) Done rereading
9:54:39 (adskflex) Server started on Adistj for: 51500ARCHDESK_2007_0F
9:54:39 (adskflex) Updating feature 51500ARCHDESK_2007_0F
9:54:39 (adskflex) Rereading options file...
9:54:39 (adskflex) ...Finished rereading
9:56:19 (lmgrd) Forced shutdown requested
9:56:20 (lmgrd) SHUTDOWN request from administrator at node adistj
9:56:20 (lmgrd) lmgrd will now shut down all the vendor daemons
9:56:20 (lmgrd) Shutting down adskflex
9:56:20 (adskflex) daemon shutdown requested - shutting down
9:56:20 (lmgrd) Shut down FLEXnet adskflex license server system on machine adistj
>>CIVIL 3D 2007 LOG>>
9:56:41 (lmgrd) pid 2192
9:56:41 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:56:41 (lmgrd) Done rereading
9:56:41 (lmgrd) FLEXnet Licensing (v10.8.0 build 18869) started on Adistj (IBM PC) (5/25/2006)
9:56:41 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
9:56:41 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:56:41 (lmgrd) World Wide Web: http://www.macrovision.com
9:56:41 (lmgrd) License file(s): C:\Program Files\Autodesk Network License Manager\License\CIV3D2007adistj.lic
9:56:41 (lmgrd) lmgrd tcp-port 27000
9:56:41 (lmgrd) Starting vendor daemons ...
9:56:41 (lmgrd) Starting vendor daemon at port 2080
9:56:41 (lmgrd) Using vendor daemon port 2080 specified in license file
9:56:41 (lmgrd) Started adskflex (pid 7948)
9:56:41 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
9:56:41 (adskflex) Server started on Adistj for: 52200CIV3D_2007_0F
9:56:41 (adskflex) PLIST
9:56:41 (lmgrd) adskflex using TCP-port 2080
9:57:08 (adskflex) TCP_NODELAY NOT enabled
9:57:09 (adskflex) OUT: "52200CIV3D_2007_0F" tsooley@TSooley-PC
5 REPLIES 5
TravisNave
in reply to: dias_ryan
Error -18 means that the License server system does not support this feature.
Chances are that for some reason the program can't find the license available on the server.
I notice you are running two license files for both products. This is not the best way to do this. You should really combine your license files into one .LIC file and run them under a single service. That'll probably fix your problem.
Just copy the INCREMENT line down for the Civil and paste it under the ADT License. No need to duplicate the PLIST one either, since it will be the same on both. That is only for license rollover.
The user guide can be found here:
http://www.macrovision.com/pdfs/flexlm_licensing_end_user_guide.pdf
Autodesk Forums:
TravisNave
To clarify...
Combine your two license files into one single file. It should now look something like this (private information not shown in this example):
SERVER Adistj 001122334455
USE_SERVER
VENDOR adskflex port=2080
INCREMENT 51500ARCHDESK_2007_0F adskflex 1.000 permanent \
INCREMENT 52200CIV3D_2007_0F adskflex 1.000 permanent \
INCREMENT PLIST adskflex 1.000 permanent \
Note that the header doesn't need to be copied, only the Increment line and the encrypted code with it (not shown here.)
On the Config Services tab, configure your LMTOOLS so that it points to this new license file. You want to configure the LMTOOLS to Use Services (not use License File.) Make sure both boxes are checked then Save the service. You can pull down the box for your second service if it exists and delete the data in it. No need to run two services, just FlexLM Service 1.
Start the Service and check the Server Status. You should see both license files are recognized. The problem should be resolved.
Good luck!
Autodesk Forums:
To use both licences you must combine your two licence file.
See
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=3785782&linkID=2475323
Best regards
Franck Hervet
www.aricad.fr
a écrit dans le message de
news:5185865@discussion.autodesk.com...
ADT2007 Log>>
adistj
>>CIVIL 3D 2007 LOG>>
I had the same error yesterday.
I am using an option file with several groups.
The Group ACADUSERS did not work, although i added the feature correctly.
After experimenting with that option file, it worked as soon as i moved the line containing the definition to the beginning of the option file.
I had no time to check, but in my opinion there is any - in notepad invisible - character in the option file that causes the problem. I will check with Uedit and post the result when happened.
dias_ryan
once we combined the licenses as per the autodesk instructions both programs work ok.
Administrator Productivity
