You have to update all these 4 files not only lmgrd.
adskflex.exe, lmgrd.exe, lmtools.exe, lmutil.exe
Use this procedure except it should be for 2007 but other than that it's the
same.
http://jtbworld.blogspot.com/2005/04/upgrade-autodesk-network-license.html
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) - http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
wrote in message news:5178203@discussion.autodesk.com...
Help!
I have install the new license file of AutoCAD2007, just like the last
versions, within updating lmgrd, but the 2007 don't work and the old
versions yes (2006, 2005).
The log is:
22:34:55 (lmgrd)
22:34:55 (lmgrd) pid 2296
22:34:55 (lmgrd) Detecting other license server manager (lmgrd) processes...
22:34:56 (lmgrd) Done rereading
22:34:56 (lmgrd) FLEXnet Licensing (v10.8.0 build 18869) started on
mastercad (IBM PC) (5/17/2006)
22:34:56 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or
Macrovision Corporation. All Rights Reserved.
22:34:56 (lmgrd) US Patents 5,390,297 and 5,671,412.
22:34:56 (lmgrd) World Wide Web: http://www.macrovision.com
22:34:56 (lmgrd) License file(s): C:\Programas\Autodesk Network License
Manager\License\mastercad 00c0a8f5a618 2006.lic
22:34:56 (lmgrd) lmgrd tcp-port 27000
22:34:56 (lmgrd) Starting vendor daemons ...
22:34:56 (lmgrd) Starting vendor daemon at port 2080
22:34:56 (lmgrd) Using vendor daemon port 2080 specified in license file
22:34:56 (lmgrd) Started adskflex (pid 1504)
22:34:56 (adskflex) FLEXlm version 9.22
22:34:56 (adskflex) lmgrd version 10.8, adskflex version 9.2
22:34:56 (adskflex) Server started on mastercad for: 48800ACD_2006_0F
22:34:56 (adskflex) 46300ACD_2005_0F 47800VIZ_2005_0F 51200ACD_2007_0P
22:34:56 (adskflex) PLIST
Thank to all.
