I've got an odd issue with a computer lab using Autodesk Inventor Pro 2008.
When autocad 2008 is launched, it always gets a license error the first time. Usually the 2nd time it's launched it'll work.
I've tried setting FLEXLM_TIMEOUT, but that doesn't work. I've setup the flexlm license manager with a new license on another server, and set the clients to use it, but it does the same thing.
Now, to make matters worse, it seems to work fine in other labs, labs that are literally cloned images and should be the same.
Any have a suggestion?
