Installation & Licensing
charles1017
Message 11 of 57 (5,953 Views)
Re: Error 0xc000007b while starting AutoCad 2013
09-28-2012 11:46 AM in reply to: charles1017
OMG it still doesnt work
after i removed the .NET frameworm 4.0 and reboot, I still get the same error 0xc000007b
dont know if it is related to .net problem
charles1017
Message 12 of 57 (5,933 Views)
09-29-2012 08:40 AM in reply to: charles1017
In addition, I borrowed my friends AutoCad 2012 and install on the same machine and OS.
It works like charm!!!
charles1017
Message 13 of 57 (5,881 Views)
10-04-2012 10:01 PM in reply to: charles1017
push~
charles1017
Message 14 of 57 (5,868 Views)
10-05-2012 08:29 PM in reply to: charles1017
to the top~
charles1017
Message 15 of 57 (5,794 Views)
10-12-2012 09:46 PM in reply to: charles1017
anyone can help???
charles1017
Message 16 of 57 (5,765 Views)
10-15-2012 08:48 AM in reply to: charles1017
Please help:smileysad: !!!
Product Support
emily.xu
Message 17 of 57 (5,753 Views)
10-15-2012 07:24 PM in reply to: charles1017
Hi,Charles
So sorry for my delay reply,I just think of another possible solution we can try, which is the Service Pack. So, did you install any Service Pack for AutoCAd 2013? If yes, just uninstall it,run autocad see if woks.If no, please download here and apply the latest Service Pack 1.1, see if works.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
charles1017
Message 18 of 57 (5,713 Views)
10-19-2012 05:53 PM in reply to: charles1017
just applied the update, still 0xc000007b......
is there any kind of log that the autocad will generate automatically once it failed to start?
coz it will be so much easier for me to tackle the problem
thanks!
Product Support
emily.xu
Message 19 of 57 (5,671 Views)
10-22-2012 12:39 AM in reply to: charles1017
From what I know, there will be a acad.err log file created when you get the fatal error, but I don't think there are some helpful info in it, except record the fatal error code, but not the reason. And it's a complex process to troubleshooting such type of error.
So, now I would suggest you try to remove all Autodesk product and reinstall under a clean environment. You can refer to this solution on how to remove all.
Before reinstallation:
1  Please login your machine with a admin user
2  Be sure to turn off anti-virus and firewall
3  Empty your temp folder
4  Turn off UAC if you use Windows 7 system
5  Close any other applications running.
Emily Xu
charles1017
Message 20 of 57 (5,621 Views)
10-27-2012 01:08 AM in reply to: charles1017
i cant even start the reinstall program, i remember there are 0xc00007b error(for AutoCAD2013 and AutoSync only) when i uninstall the program through control panel BEFORE, but now, it says the program is already removed and all it does is to remove the entry in the control panel.
but then i use "ADSUninstallTool.exe" to uninstall the program. is that ok?
will report again after reinstall
thanks
