Installation & Licensing
Member
jv13
Message 1 of 8 (4,374 Views)
Error 0xc000007b when I running 3ds max 2014
4374 Views, 7 Replies
09-02-2013 11:35 AM
I have installed the trial version of 3ds max 2014 and when I trying to running it, I have an error message => 0xc000007b.
Only 3ds max 2014 are concerned by this problem. Others programs run without problems.
Virus scan => done
Registery check => done
Google => done ^^
Windows 7 professionnal 64 bits
All drivers are up to date.
Thank you very much for your help.
Have a nice day !
PS : Sorry for my english, I'm french (I know that doesn't excuse anything... ^^)
Product Support
aaronhai
Message 2 of 8 (4,352 Views)
Re: Error 0xc000007b when I running 3ds max 2014
09-02-2013 09:43 PM in reply to: jv13
Hi jv13,
Welcome to Autodesk Discussion Group.
Please perform a clean re-installation of the product and see if that works for you.
Thank you.
Aaron Hai
Member
jv13
Message 3 of 8 (4,344 Views)
09-03-2013 06:17 AM in reply to: aaronhai
Thank you for your answer. I have re-installed 3ds max 2013 but this problem persists :smileysad:
Have a nice day !
TravisNave
Message 4 of 8 (4,335 Views)
09-03-2013 07:55 AM in reply to: jv13
This problem almost always requires DLL replacement of either Visual C++ or DirectX.
For example, please follow the instructions found at the bottom of page 3 on this thread:
http://forums.autodesk.com/t5/Installation-Licensing/Error-0xc000007b-while-starting-AutoCad-2013/td...
There are a lot of searchable fixes for this error, should this one not pan out.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Product Support
dembkod
Message 5 of 8 (4,325 Views)
09-03-2013 09:26 AM in reply to: jv13
jv13 ,
Hello. Fatal errors are usually caused by a few different things. First, installation corruption. Usually a clean uninstall will take care of this. Past this, a graphics card incompatibility or a driver conflict can cause this issue as well.
Update your graphics card, not through Windows Update. Go to the manufacturer or your graphics card and download the latest few drivers and test them to see if any of them let the program run.
Thank you for taking part in our community!
David Dembkoski
Member
jv13
Message 6 of 8 (4,295 Views)
09-06-2013 05:45 AM in reply to: jv13
I have re-installed 3ds max 2014 three times, and the error persists again. I have tried to use Dependency Walker and it displays this :
http://nsa35.casimages.com/img/2013/09/06/130906024713149389.png
http://nsa35.casimages.com/img/2013/09/06/130906024711684656.png
What should I do ?
Thank you very much and have a nice day !
Product Support
dembkod
Message 7 of 8 (4,283 Views)
09-06-2013 08:47 AM in reply to: jv13
jv13,
Hello. I would make a copy of your Setup.ini file and then edit the original setup.ini. Replace all instances of PREREQUISITES with # PREREQUISITES and save the file. Now try to install. This will avoid trying to install the prerequisites. If you are having an issue there it may avoid it.
You can always manually install the reqs from the 3rd party folder in the installer.
David Dembkoski
New Member
dehjau
Message 8 of 8 (1,177 Views)
05-27-2014 06:58 AM in reply to: TravisNave
Galera, resolvi o problema na inicialização do 3ds max 2015, removendo todas as versões do Visual C + + do windows, passei o ccleaner e adicionei o mfc110u.dll no system32
