Instalei opacote de programas Arquitectural Mep etc nos computadores da minha rede.
mas na minha máquina dá um erro na instalação dos material libary 2013.
junto anexo fixeiro do log da instalação .
gostava de saber se tem solução para isto?
Cumprimentos
Marco Alves
Hi Marco,
Please can you try to install manually the BaseImageLibrary2013, and if it finish correctly, then try to install AutoCAD Mep 2013. The setup will recognize that the library is already installaed and should skeep this step.
You can find this library in the original product download or DVD folder at
...\Content\ADSKMaterials\2013\ILB\BaseImageLibrary2013.msi
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Please, can you try to install launching Windows in diagnostic mode?
http://usa.autodesk.com/getdoc/id=TS1054234
