Hi, I'm recieving this error while trying to install Creation Suite 2012, and I'm aware that there is a solution to a problem like this out there, however, this solution assumes you are trying to install the suite on a secondary hard drive. I am simply trying to install it on C:. Apparently, in the window that tells me that there is no space for download, it says that my disk drive D:(Where I have the installer) has a negative amount of space. I've tried clicking "OK", but even after this, it tells me: "Please insert the disc: none". Thank you for reading.
Please continue this thread here:
