I am downloading my license on a laptop so I can work from home. I received the message "Please insert the disk: AutoCAD 2016 Disk1"
As this was purchased electronically, I don't have any discs. What can be done?
@Anonymous
Welcome to the community..
How are you download your Autodesk application? Install now, download manager, virtual agent?
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
This message is because you are trying to install the product from removable media (USB drive or DVD). Try to copy the installer to a local drive (C or D) and run it.
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue. Where any of the above replies helpful to you?
If so, please select a response that resolved the issue and click "Accept As Solution" button to help others in the community.
Thank you for posting!
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thanks for the help. I was attempting to download by copying the program files to the laptop from my workstation. I didn't realize that it could be done from your website. After receiving your response, I downloaded the program and entered my product key and everything worked fine.
