Installation & Licensing
2 REPLIES 2
MikeEvansUK
516 Views, 2 Replies
I can't install the ecsu product, it fails on 3dsmax install.
Dialogue, "Error writing to file, c:\users\user\documents\3dsmax\sceneassets\images\colors.jpg, verify you have access"
I have access, the folder is empty but structure is read only. Tried removing readonly setting to no avail, tried creating "dummy file" to no avail.
Any suggestions?
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
2 REPLIES 2
TravisNave
in reply to: MikeEvansUK
Mike,
You don't move the docs folder to another network resource do you?  Like roaming profiles or redirected folders?
Also, I assume you have local admin rights, UAC is off, and anti-virus disabled?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
MikeEvansUK
Following product support advice, In windoes 7 turn UAC off, Turn off Windows defender and uninstall Virus software (im my case Panda) just turning it off didn't work.
The product then installed correctly.
Case closed.
M.
Mike Evans
Administrator Productivity
