Solved by muna.qanadilo. Go to Solution.
Hi @muna.qanadilo and welcome to the Autodesk Community!
For direct activation and licensing assistance, please contact our License Assistance team by clicking on this link and then following the prompts:
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
You will be able to contact the License Assistance Team either via Chat or e-mail.
Thank you
This error can be repaired by following the steps on the link below
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Right after you do this go back to install the software and go through the activation process so you can get a request code.
I've got simillar problem with Maya 2015 on Mac os. Could you recommend me something?
Thank you!
found this: http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Uninstall-from-MAC.html
DarrenP
The link you shared no longer works. Here is the updated link:
https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod...
