I downloaded DWG TrueViewer and loaded the upgrade NET.framework 4.0. I cannot find the viewer anywhere. It is not on the desktop, in the Program Folder, nor in the Open With window. It is on the Control Panel, Add/Delete Programs folder.
How do I set it up and run it. I want to open and look at a .dwg file.
Thank you in advance.
setup should be run manually.
It should be in C:\Autodesk, if you can't find please download it again.
