Installation & Licensing
New Member
kristinn66
Message 1 of 7 (1,429 Views)
DWG TrueView hangs at "Loading plug-ins... accoremgd.dll
1429 Views, 6 Replies
06-13-2012 02:37 PM
Hi there,
I installed DWG TrueView on win 7 64bit laptop.
When I start it for the first time It just hangs at loading plug-ins.
I have tryed to reinstall but still the same.
Hope some one will be able to help.
thanks
*Expert Elite*
TravisNave
Message 2 of 7 (1,428 Views)
Re: DWG TrueView hangs at "Loading plug-ins... accoremgd.dll
06-13-2012 02:50 PM in reply to: kristinn66
How long have you waited?  Have you tried launching it as another user or as Administrator?
New Member
kristinn66
Message 3 of 7 (1,426 Views)
06-13-2012 02:53 PM in reply to: kristinn66
I have waited about 20 min 3 times.
2 of those times I right cliked and did run as admin.
I have not tried as another user will try that now
edit
Have tryed as another user with admin rights  no luck   same thing happens.
*Expert Elite*
TravisNave
Message 4 of 7 (1,400 Views)
06-15-2012 09:08 AM in reply to: kristinn66
New Member
next.
Message 5 of 7 (1,096 Views)
01-11-2013 05:27 AM in reply to: kristinn66
Same problem with AUTOCAD 2013 LT.
We have reinstalled, but nothing changed.
PLS HELP US A.S.A.P. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Member
jeromej
Message 6 of 7 (507 Views)
11-13-2013 08:13 AM in reply to: next.
Same problem with TrueView 2013 and 2014.
Unload the Trend Micro Antivirus, check for some Microsoft Updates but same issue.
Hang at "Loading plug-ins... accoremgd.dll".
We don't have this problem on AutoCad 2013/2014 LT for the moment, but it makes us fear the worst in the near future.
Any idea or source of this problem to explore? (.NET, MS update, MS or Autodesk fixit?)
Jerome
Product Support
dembkod
Message 7 of 7 (505 Views)
11-13-2013 08:20 AM in reply to: kristinn66
kristinn66 ,
Hello. Log in with a different user account and see if the program starts. If it does, there could be an issue with eth Windows Profile you are using.
You can always uninstall NET and reinstall to see if it helps. It would also be a good idea to update your Graphics Card driver if you have not done so in a while.
It is possible the Windows Event Viewer may have a log for the event. If it does it may point to a specific module. If you have Internet Explorer 10 installed, it may be worth rolling back to 9. IE 10 has caused issues with lots of programs. There is an outside chance it is connected.
Thank you for taking part in our community!
David Dembkoski
Need installation help?
