Problems trying to install DWG TrueView 2012 on Windows 7 Ultimate, 64-bit.
I have tried installing the 64-bit version of TrueView. The installation stops and an error message says to install Microsoft .NET Framework 4.0 or higher. However .NET 4.0 is already installed.
I tried the 32-bit version of TrueView but it would not install.
I restored .NET and reinstalled all updates. Still no luck.
TrueView 2011 ran fine on this platform. However I do not have the original spurce files for that version.
Has anyone had this problem and found a fix?
Alternatively, is the 2011 version of TrueView 64-bit still available to download?
Nigel
I apologize for the inconvenience blort,
Have you checked out AutoCAD WS? It's a free hosted software that allows for DWG viewing, sharing, and editing.
I am facing the same problem. I just reinstalled XP and updated to SP3.
I installed:
dotNetFx40_Client_setup
wic_x86_enu
NDP40-KB2468871-v2-x86
then I install
SetupDWGTrueView2013_32bit
It says I did not install .NET 4.0. What happen?
If you install the Autodesk Design Review it will automatically download the .NET 4.0 in the download and install process. To get DWG TrueView, just check the box to also install DWG TrueView prior to downloading the Design Review.
You can still download via browser.
Cancel download via autodesk download manager and go to help button that you see only after canceling download.
There you can select browser download...
Installing Autodesk Trueview. Man, that only took about 6 hours of my life from me....on a job site in saudi arabia and with my personal laptop. about noon I am told I need to review several drawings. "oh, i'll just install autocad teamviewer and happy days and then go have lunch...."
it literally took me from lunch until 10 PM to get this thing sorted. deduct 1 hour for lunch and driving back to the compound....1 hour for phone call with family and 1 hour for getting some work done!
this whole MS Service Pak 4.0 Update is tough...man, i almost gave up several times. I did stop to have some shwarma but it was generally an incredibly frustrating experince.
You guys really killed me with that Akamai net session interface. After trying to get past that for an hour I almost gave up right then. Instead, i found this Blog which got around that: http://blog.jtbworld.com/2012/05/autodesk-dwg-trueview-2013-download-and.html
I agree with the other poster: why force us through Akamai?
Ok, fine, i download and am told I don't have the right .Net framework....
Then I went into the MS Download rabbit hole for a very, very long time. I didn't have to uninstall anything but I did reboot a lot and I did download a lot of unneccessary items from MS. A lot of google searches and a lot of educated guesses. This seems to be pretty common and there are a lot of dead end blogs out there.
Finally i want to thank this guy whose blog i only found about 1 hour ago: http://withoutanet.typepad.com/without_a_net/2012/05/microsoft-net-framework-4-sp1.html
His link took me to the REAL link i needed for the SP. I spent a lot of time wondering what the heck was going on and it was his link that save me.
ALS
You have to install Microsoft .NET Framework 4 Extended:
http://www.microsoft.com/en-us/download/details.aspx?id=17718
I got it to work on a Win7 64-bit system.
I uninstalled NET 4 from control panel.
rebooted.
Download NET 4 from sonnen_x link above.
Rebooted.
Ran "critical" windows updates.
Rebooted.
Re-tried installation and it worked!
I know this started out with True View 2012 and was resolved by fiddlling with .net framework.
and
I looks like the same confusion exists with 2013 TrueView.
and the same solution works... fiddling with .net framework.
And 2013 give me the same dumb stare. "need to updae to 4.0 SP1" with no direction.
Would be nice to have some installing support up front.
Dropping in the suggesion box and I hope I get picke for suggestion of the month and the $100.00 reward.
You have to install the server/developer version. AutoDesk should tighten-up their programming. Seriously, This is just a viewer and it's taken almost an hour to figure this out. Why is any of this acceptable..? BUSH-LEAGUE..!!!
First you must install Microsoft .NET Framework 4 KB2468871 and then install the update NDP40-KB2468871-v2-x64 0r NDP40-v2-x86.
Dear Sir,
Thank you so much for the reply. But the problem is I can never find tese .NET!!!!
I really cannot believe both Microsoft and Autodesk these two such large company cannot solve such a simply thing.
Big boss on top, learn from Steve Jobs, make things simple, not more complex to proof you are worth the salary.
This extends to .Net Framework 4.5 Full.
I have Windows 8 64 Bit. Trying to install Trueview 2014.
The error message is
.NET version check
You must first install Microsoft .NET Framework version 2.0 before installing this product.
OK
Really? Trueview 2014, .Net 2.0?
I'm going to try 4.0 and hope it doesnt screw me up.
I'll let you know.
So 4.0 doesn't work. Won't even install.
Details
Microsoft .NET Framework 4 is already a part of this operating system. You do not need to install the .NET Framework 4 redistributable. http://go.microsoft.com/fwlink/?LinkId=164207 More information.
Same or higher version of .NET Framework 4 has already been installed on this computer.
Try 2.0 and see what happens.
Couldn't install 2.0.
In the end the .Net 3.5 includes 2.0 and 3.0 needed to be installed.
Got it working. What a lot of mucking around though.
In order to install TrueView. I reinstalled my computer with XP SP2. Again I was pointing to here and there on .NET.
After spending hours, I gave up.
I cannot believe such a large company can screw up so much.
what the proplem
I'm trying to install TrueView on XP, have tried every one of the suggestions here and have wasted a lot of time, to no avail. I have tried installing on 4 diffentent computers and the all say I need net framework 4.0 SP1 even though it is already installed. I see installing net framework 4.0 extended has worked for others here but it hasn't work for me.
Such a shame!!
Dear: I could install DWG TrueView 2013 in Windows Xp Sp3.
Steps I did to install it:
1 - Download and Install. Net Framework 4 Full:
Link -> http://www.microsoft.com/en-us/download/details.aspx?id=17851
(Restart after install)
2 - Download and install Update Components. NET Framework 4:
Link -> http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=3556
Filename for XP 32-bit: "NDP40-KB2468871-v2-x86.exe"
(Restart after Install)
After installing this update, I was able to install DWG.
3 - Install DWG TrueView 2013.
Ready!
_________________
probe only the installation of DWG TrueView 2013 on Windows XP SP3, windows 7, and for those who have this problem in the operating system, try the steps 1,2,3.
Greetings from Chile.
Finally success on Windows 7 x64 with DWG TrueView 2014 x64
I've met “DWG TrueView does not recognize .NET 4.0” problem on fully updated system with all optional .NET 4.0 components from Windows Update.
The one and only solution is installing Microsoft .NET Framework 4.5 (http://www.microsoft.com/en-us/download/details.aspx?id=30653) “a highly compatible, in-place update to .NET Framework 4.”
