Installation & Licensing
Member
nbrown
Message 11 of 40 (47,497 Views)
Re: DWG TrueView does not recognize .NET 4.0
12-09-2011 07:15 AM in reply to: nbrown
The solution was to install a full version of .NET 4.0.  Windows 7 comes with a partial installation so it appears that the program is present.  But it is not the full-blown program.  You can download the full .NET 4.0 from the Microsoft website.  After installing it, DWG TrueView installed normally.
New Member
donmartin53
Message 12 of 40 (47,291 Views)
03-04-2012 01:57 PM in reply to: iraiam
Thanks for the help. The NET Framework 4.0 Full did the trick.
Don
New Member
feddex
Message 13 of 40 (47,221 Views)
03-28-2012 05:32 AM in reply to: nbrown
Here's my findings as I'm experiencing the same issue with 2013 TrueView (error telling me I need to install .NET framework 4.0 SP1
  ->C:\Windows\Microsoft.NET\Framework64\v2.0.50727
4.0.30319.1
  ->C:\Windows\Microsoft.NET\Framework64\v4.0.30319
< Installed .NET Frameworks >
.NET FW 1.1
.NET FW 2.0 SP 2
.NET FW 3.0 SP 2
.NET FW 3.5 SP 1
.NET FW 4.0 Client
.NET FW 4.0 Full
I've installed the latest MS has to offer, and still, I can't get this to run.  I'm using Windows7 Professional x64.  Help
New Member
iviit
Message 14 of 40 (47,141 Views)
03-30-2012 07:54 AM in reply to: nbrown
We had a similar problem. It looked like .NET 4 Full was already installed, but we kept getting the minimum .NET 4 sp 1 message when trying to install DWG Trueview 2013.
Installing Microsoft .NET Framework 4 KB2468871 solved our problem.
Hope this helps.
New Member
CADuser101
Message 15 of 40 (47,122 Views)
03-30-2012 11:14 AM in reply to: nbrown
Windows XP 32-bit -- *** FIXED ***
We have several XP-Pro 32-bit machines.  Even after the suggested .NET 4.0 Client & Full install, none of our machines would get past the “.NET 4.0 SP1 or later required” message.  The TrueView installer is specifically checking the registry for installation of Microsoft KB2468871.  Even if you’ve just downloaded and installed .NET 4.0, the TrueView installation will fail unless update KB2468871 is also installed.
Download from http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=3556
Filename for XP 32-bit: “NDP40-KB2468871-v2-x86.exe”
I see another poster just discovered the same solution.  I had to use procmon.exe to see the registry query.
New Member
ddumond
Message 16 of 40 (46,333 Views)
04-19-2012 08:39 AM in reply to: nbrown
I am trying to install TrueView 2013 64 bit on Windows 7 machine.  I have been getting the same .Net 4.0 not installed message described above but nonoe of the fixes described has worked for me so far.  I have uninstalled and re-installed .Net 4.0 from Microsoft, installed the 64 bit version of the patch from KB2468871 all to no avail.  Is anyone else continuing to suffer this problem or are there any other ideas to try?
Valued Contributor
sahilchopra
Message 17 of 40 (41,484 Views)
07-16-2012 03:39 AM in reply to: nbrown
ive got the same porblem and no solution.
Member
nbrown
Message 18 of 40 (41,473 Views)
07-16-2012 06:21 AM in reply to: sahilchopra
The version of .Net 4.0 that comes as part of Windows 7 is not the full program. Go to the Microsoft site and download the full version of .Net 4.0 (free). Install it and DWG TrueView will run fine.
New Member
keabus
Message 19 of 40 (36,844 Views)
09-14-2012 04:06 AM in reply to: iraiam
Completely true solution, it worked for me :smileyhappy: Thank you.
New Member
blort
Message 20 of 40 (36,625 Views)
09-16-2012 10:45 PM in reply to: nbrown
I would like to thank the creators of DWG TrueView 2013 for wasting my evening. I installed .NET 4 Full, KB2468871, rebooted, and it still won't install. I'd also like to thank all of autodesk for making it take much longer to download your useless software by forcing akamai net downloader on me. Akamai is intrusive, unnecessary, and non-functional. The alternate download will only redirect me to the x86 version of DWG TrueView which is incompatable with W7 x64 (also should not be an issue since x64 is perfectly capable of running most x86 applications). I had to rely on some Czech based autodesk forum for a dowload of DWG TrueView x64 at about 50 KB/s. All of this to find it still will not install. Seriously, you all know what you can do to yourselves. Cutting my losses and finding another .dwg viewer.
