Installation & Licensing
Member
nbrown
Message 1 of 40 (28,490 Views)
DWG TrueView does not recognize .NET 4.0
28490 Views, 39 Replies
08-15-2011 03:36 PM
Problems trying to install DWG TrueView 2012 on Windows 7 Ultimate, 64-bit.
I have tried installing the 64-bit version of TrueView.  The installation stops and an error message says to install Microsoft .NET Framework 4.0 or higher.  However .NET 4.0 is already installed.
I tried the 32-bit version of TrueView but it would not install.
I restored .NET and reinstalled all updates. Still no luck.
TrueView 2011 ran fine on this platform.  However I do not have the original spurce files for that version.
Has anyone had this problem and found a fix?
Alternatively, is the 2011 version of TrueView 64-bit still available to download?
Nigel
Product Support
david.lau
Message 2 of 40 (28,440 Views)
Re: DWG TrueView does not recognize .NET 4.0
08-17-2011 01:21 PM in reply to: nbrown
Can you log a case and Product Support can send you the URL for the 2011 TrueView x64?
Can you also check out these reference posts:
http://forums.autodesk.com/t5/DWG-TrueView/DWG-Trueview-require-Framework-4/td-p/3015044
http://forums.autodesk.com/t5/Installation-Licensing/DWG-Trueview-2011-error-Unable-to-run-DWG-Truev...
http://usa.autodesk.com/getdoc/id=TS16436702
David Lau
Member
iraiam
Message 3 of 40 (28,423 Views)
08-18-2011 07:14 PM in reply to: david.lau
I have this same problem trying to install TrueView 2012 32 bit on windows XP pro,  I had .NET framework 4.0 already and Installed a security update for it, still no luck. error is "You must first install Microsoft .NET Framework version 4.0 or greater before installing this product."
Employee
HelenChen-Autodesk
Message 4 of 40 (28,403 Views)
08-19-2011 04:23 AM in reply to: iraiam
Could you please try this tool to check what .net Framework you have installed in your machine?
http://www.asoft.be/prod_netver.html
Helen
Member
iraiam
Message 5 of 40 (28,393 Views)
08-19-2011 05:21 PM in reply to: HelenChen-Autodesk
Ok, thanks much,  this is the result.
<32Bit>
1.1.4322.2470
  ->C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322
2.0.50727.3623
  ->C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
4.0.30319.237
  ->C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319
< Installed .NET Frameworks >
.NET FW 1.1 SP 1
.NET FW 2.0 SP 2
.NET FW 3.0 SP 2
.NET FW 3.5 SP 1
.NET FW 4.0 Client
I am thinking I need NET FW 4.0 "Full Framework" installed, Is that correct? I'm downloading it as I type to try it.
Member
iraiam
Message 6 of 40 (28,391 Views)
08-19-2011 05:45 PM in reply to: iraiam
Thank you, that was the problem.
<32Bit>
1.1.4322.2470
2.0.50727.3623
4.0.30319.237
.NET FW 1.1 SP 1
.NET FW 2.0 SP 2
.NET FW 3.0 SP 2
.NET FW 3.5 SP 1
.NET FW 4.0 Client
.NET FW 4.0 Full   *********  THIS WAS MISSING********
I got the .NET FW 4.0 FULL here
http://www.microsoft.com/download/en/details.aspx?id=17718
Thanks again
Employee
HelenChen-Autodesk
Message 7 of 40 (28,360 Views)
08-22-2011 03:50 AM in reply to: iraiam
Yeah, you are right. The Full version of .Net 4 is needed to be pre-installed.
It's very glad you have resolved your problem. :smileyhappy:
Helen
Member
nbrown
Message 8 of 40 (28,326 Views)
08-22-2011 01:32 PM in reply to: HelenChen-Autodesk
Thaw
Member
nbrown
Message 9 of 40 (28,319 Views)
08-22-2011 01:35 PM in reply to: HelenChen-Autodesk
That worked for me too.  Thank you very much for your help!
Nigel
New Member
waltspar
Message 10 of 40 (26,704 Views)
12-09-2011 07:03 AM in reply to: nbrown
Did you ever get a resolution? I am having the same issue with Trueview 2012 and Windows XP PRO 32bit.  I have updated the Framework, including completely removing and reinstalling - no joy.
It's time to re-evaluate "how you've always done it"…
