Installation & Licensing
DWG TrueView 2015 Launch Problem - 0xc0000142 application error
7 REPLIES 7
Message 1 of 8
ekipp42
8236 Views, 7 Replies
When I try to launch DWG TrueView 2015, I get the following error message.  What can I do to fix this issue?
7 REPLIES 7
Message 2 of 8
pendean
in reply to: ekipp42
Message 3 of 8
ekipp42
I saw this solution and tried it before I posted my issue.  I do not have Adobe Acrobat installed on my computer.  I only have the reader (version 11) and flash player (version 12) installed.  I tried to uninstall the reader, uninstall TrueView and then reinstall TrueView with the same problem.  Would there be another program interferring with the launch of this program?
Message 4 of 8
sinotsar
Besides uninstalling a program so Autocad can run is hardly a solution. I need Adobe Pro as much as I need Autocad and the autoruns solution is to complicated, I'm a user not a tech geek. Autocad fix your ****!
Message 5 of 8
TravisNave
in reply to: sinotsar
It's not Autodesk's **** to fix.  The problem is how Adobe writes its plugins.  If you remove it and then reinstall it after Autodesk installation, then you should have no issue.
Autodesk Forums:
Message 6 of 8
sinotsar
in reply to: TravisNave
If it is adobes fault then why does every other program I use work with it? Maybe autocad should take a look at how it handles the way adobe writes their plugins...
anyhow, turns out it was not acrobat afterall, i had to use that autoruns program and found that an audio capture dll was the one the autocad didn't like, I can live without it so I uninstalled it and all is fine now.
Of couse this used up almost half my day... I expect more from a program which costs thousands of dollars.
Message 7 of 8
TravisNave
I believe the expectations are rather too high for programs that are free.  Smiley Wink
Autodesk Forums:
Message 8 of 8
pendean
DTV is freeware: you're confusing issues now after blowing a half day.
Administrator Productivity
