Installation & Licensing
Download Failed, Installation aborted, Result=1603
3 REPLIES 3
davef101
1618 Views, 3 Replies
3 REPLIES 3
david.lau
in reply to: davef101
What product?  What operating system?  A 1603 error indicates that the software didn't install.  That is a very generic error code.
David Lau
TravisNave
I wrote an article about this issue.
http://forums.autodesk.com/t5/Installation-Licensing/Download-Failed-Installation-aborted-Result-160...
Basically, you can install your software from the virtual assistant instead and be good to go:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Autodesk Forums:
davef101
in reply to: TravisNave
The following actions were taken to resolve the service pack 1 install
error 1603 after installing autocad 2014 on windows 8:
1. Deleted all existing "temp files" and then installed service pack
1. No more issues and no error 1603.
Administrator Productivity
