Installation & Licensing
Download Error for REVIT 2013
3 REPLIES 3
2450 Views, 3 Replies
I have been trying to download Revit 2013 for 64 bit Windows (I run Windows 7 64 bit) read through all the other download errors *to search for possible solutions* but i've not been able to download it.
Here are some of the logs that I've got:
1. This one is when i almost got it, where it states that Revit has been succesfully installed but there's a faroSDK error..
 === Setup started on USER by 0wner ===
2012/11/17:16:02:16 0wner USER Launch
2012/11/17:16:02:19 0wner USER Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2012/11/17:16:02:20 0wner USER PageOpen LaunchDialog
2012/11/17:16:06:11 0wner USER PageOpen LicenseDialog
2012/11/17:16:06:11 0wner USER PageOpen ProductInfoDialog
2012/11/17:16:06:11 0wner USER PageOpen ProductSelectionDialog2
2012/11/17:16:06:19 0wner USER PageOpen FullProgressDialog
2012/11/17:16:06:19 0wner USER Installing .NET Framework Runtime 3.5 SP1 Language Pack: C:\Autodesk\WI\Autodesk Revit 2013 /q /norestart /c:"install.exe /qn"
2012/11/17:16:06:19 0wner USER Install .NET Framework Runtime 3.5 SP1 Language Pack Failed Failure is ignored, Result=2
2012/11/17:16:06:20 0wner USER Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2012/11/17:16:06:20 0wner USER Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/17:16:07:00 0wner USER Install DirectX® Runtime Succeeded
2012/11/17:16:07:00 0wner USER Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2012/11/17:16:07:00 0wner USER Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\0wner\AppData\Local\Temp\FaroSDK.log"
2012/11/17:16:07:07 0wner USER Install FaroSDK Succeeded
2012/11/17:16:07:10 0wner USER Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:17:56:23 0wner USER Download Complete RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:17:56:23 0wner USER Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\0wner\AppData\Local\Temp\_AI80E2.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:12:42 0wner USER Install Autodesk® Revit® 2013 Succeeded Reboot is required
2012/11/17:19:12:45 0wner USER Download Play RVT2013_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:19:14:45 0wner USER Download Complete RVT2013_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:19:14:46 0wner USERY Installing Autodesk® Revit® 2013 Language Pack: TRANSFORMS="C:\Users\0wner\AppData\Local\Temp\_AI80E2.tmp\_laBDE1.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:14:48 0wner USER Install Autodesk® Revit® 2013 Language Pack Succeeded
2012/11/17:19:14:49 0wner USER Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CM2...
2012/11/17:19:21:13 0wner USER Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CM2...
2012/11/17:19:21:13 0wner USER Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:21:20 0wner USER Install Autodesk Material Library 2013 Succeeded
2012/11/17:19:21:21 0wner USER Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:19:30:02 0wner USER Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:19:30:02 0wner USER Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:30:06 0wner USER Install Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/17:19:30:07 0wner USER Download Play CMILL2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:31:36 0wner USER Download Complete CMILL2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:31:36 0wner USER Installing Autodesk Material Library 2013 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:20:31:46 0wner USER Install Autodesk Material Library 2013 - Low Image Library Succeeded
2012/11/17:20:31:48 0wner USER Download Play CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:54:18 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:55:10 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:56:12 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:56:12 0wner USER Download Paused CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:56:52 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:58:54 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:02:17 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:07:49 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:18:29 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:39:49 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:08:52 0wner USER Download User Resume CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:25:19 0wner USER Download Error CMILM2013 <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:25:19 0wner USER Download Aborted CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:25:19 0wner USER Install Autodesk Material Library 2013 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2012/11/17:22:25:20 0wner USER Rollback Autodesk Material Library 2013 - Low Image Library Succeeded
2012/11/17:22:25:26 0wner USER Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/17:22:25:34 0wner USER Rollback Autodesk Material Library 2013 Succeeded
2012/11/17:22:25:36 0wner USER Rollback Autodesk® Revit® 2013 Language Pack Succeeded
2012/11/17:22:26:28 0wner USER Rollback Autodesk® Revit® 2013 Succeeded
2012/11/17:22:26:28 0wner USER Rollback FaroSDK Failed Failure is ignored, Result=1619
2012/11/17:22:26:28 0wner USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/11/17:22:26:28 0wner USER PageOpen InstallCompleteDialog
2012/11/17:22:30:25 0wner USER === Setup ended ===
and log 2:
2012/11/18:01:05:33 0wner USER Launch
2012/11/18:01:05:36 0wner USER Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2012/11/18:01:05:36 0wner USER PageOpen LaunchDialog
2012/11/18:01:08:15 0wner USER PageOpen LicenseDialog
2012/11/18:01:08:15 0wner USER PageOpen ProductInfoDialog
2012/11/18:01:08:15 0wner USER PageOpen ProductSelectionDialog2
2012/11/18:01:13:53 0wner USER PageOpen FullProgressDialog
2012/11/18:01:13:54 0wner USER Installing .NET Framework Runtime 3.5 SP1 Language Pack: C:\Autodesk\WI\Autodesk Revit 2013 /q /norestart /c:"install.exe /qn"
2012/11/18:01:13:54 0wner USER Install .NET Framework Runtime 3.5 SP1 Language Pack Failed Failure is ignored, Result=2
2012/11/18:01:13:55 0wner USER Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2012/11/18:01:13:55 0wner USER Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/18:01:14:28 0wner USER Install DirectX® Runtime Succeeded
2012/11/18:01:14:29 0wner USER Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2012/11/18:01:14:29 0wner USER Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\0wner\AppData\Local\Temp\FaroSDK.log"
2012/11/18:01:14:33 0wner USER Install FaroSDK Succeeded
2012/11/18:01:14:34 0wner USER Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/18:01:14:34 0wner USER Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\0wner\AppData\Local\Temp\_AI8853.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:01:14:34 0wner USER Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618
2012/11/18:01:14:34 0wner USER Rollback FaroSDK Failed Failure is ignored, Result=1618
2012/11/18:01:14:34 0wner USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
what did i do wrong? please help ! *thanks in advance*
3 REPLIES 3
david.lau
Please try a browser download if possible.
David Lau
I have the same issue. I tried the browser download and that did not work either. What can I do to fix this?
I have the same problem with Install Now, Browser and so on..it never complets the download!
Administrator Productivity
