Installation & Licensing
Download error for 3ds max 2013
0 REPLIES 0
Message 1 of 1
kaiser.abcdef.lee
1040 Views, 0 Replies
I've Tried to run the installer a few times, and when it fails, it says that I can run it later to install the remaining items.
2013/1/3:12:16:49 Kaiser KAISER-PC === Setup started on KAISER-PC by Kaiser ===
2013/1/3:12:16:49 Kaiser KAISER-PC Launch
2013/1/3:12:16:49 Kaiser KAISER-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/Autodesk_3ds_Max_2013_EFGJKS_Win_32-64b..." /SN 900-35758403 /PK 128E1 /student /skipEULA /akamai /auth /sid
2013/1/3:12:22:42 Kaiser KAISER-PC === Setup ended ===
2013/1/3:12:16:52 Kaiser KAISER-PC === Setup started on KAISER-PC by Kaiser ===
2013/1/3:12:16:52 Kaiser KAISER-PC Launch
2013/1/3:12:19:56 Kaiser KAISER-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:20:02 Kaiser KAISER-PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:20:23 Kaiser KAISER-PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:21:14 Kaiser KAISER-PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:21:14 Kaiser KAISER-PC Download Paused SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:22:41 Kaiser KAISER-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:22:42 Kaiser KAISER-PC PageOpen LaunchDialog
2013/1/3:12:31:59 Kaiser KAISER-PC PageOpen LicenseDialog
2013/1/3:12:31:59 Kaiser KAISER-PC PageOpen ProductInfoDialog
2013/1/3:12:31:59 Kaiser KAISER-PC PageOpen ProductSelectionDialog2
2013/1/3:12:35:43 Kaiser KAISER-PC PageOpen FullProgressDialog
2013/1/3:12:36:27 Kaiser KAISER-PC Download Play VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:36:34 Kaiser KAISER-PC Download Error VCREDIST2005SP1ATLX86 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:36:52 Kaiser KAISER-PC Download Complete VCREDIST2005SP1ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:36:52 Kaiser KAISER-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kaiser\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/3:12:37:29 Kaiser KAISER-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/1/3:12:37:31 Kaiser KAISER-PC Download Play VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:37:37 Kaiser KAISER-PC Download Error VCREDIST2005SP1ATLX64 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:37:58 Kaiser KAISER-PC Download Error VCREDIST2005SP1ATLX64 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:38:49 Kaiser KAISER-PC Download Error VCREDIST2005SP1ATLX64 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:38:49 Kaiser KAISER-PC Download Paused VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:40:01 Kaiser KAISER-PC Download Error VCREDIST2005SP1ATLX64 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:55:58 Kaiser KAISER-PC Download User Resume VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:57:36 Kaiser KAISER-PC Download Complete VCREDIST2005SP1ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:57:36 Kaiser KAISER-PC Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kaiser\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/1/3:12:58:24 Kaiser KAISER-PC Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/1/3:12:58:25 Kaiser KAISER-PC Download Play VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:58:32 Kaiser KAISER-PC Download Complete VCREDIST2010SP1X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:58:32 Kaiser KAISER-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/1/3:12:58:59 Kaiser KAISER-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/3:12:59:00 Kaiser KAISER-PC Download Play VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:59:06 Kaiser KAISER-PC Download Complete VCREDIST2010SP1X64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:59:06 Kaiser KAISER-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/1/3:12:59:25 Kaiser KAISER-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/3:12:59:26 Kaiser KAISER-PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:12:59:41 Kaiser KAISER-PC Download Error DIRECTX <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:01:45 Kaiser KAISER-PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:01:45 Kaiser KAISER-PC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/3:13:03:53 Kaiser KAISER-PC Install DirectX® Runtime Succeeded
2013/1/3:13:04:15 Kaiser KAISER-PC Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:04:22 Kaiser KAISER-PC Download Error CM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:05:56 Kaiser KAISER-PC Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:05:56 Kaiser KAISER-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/3:13:06:50 Kaiser KAISER-PC Install Autodesk Material Library 2013 Succeeded
2013/1/3:13:07:13 Kaiser KAISER-PC Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:07:19 Kaiser KAISER-PC Download Error CMILB2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:09:12 Kaiser KAISER-PC Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:09:12 Kaiser KAISER-PC Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/3:13:09:43 Kaiser KAISER-PC Install Autodesk Material Library 2013 - Base Image Library Succeeded
2013/1/3:13:10:06 Kaiser KAISER-PC Download Play CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:10:12 Kaiser KAISER-PC Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:10:33 Kaiser KAISER-PC Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:11:25 Kaiser KAISER-PC Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:11:25 Kaiser KAISER-PC Download Paused CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:20:58 Kaiser KAISER-PC Download Error CMILM2013 Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:20:59 Kaiser KAISER-PC Download Aborted CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:13:20:59 Kaiser KAISER-PC Install Autodesk Material Library 2013 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/1/3:13:21:40 Kaiser KAISER-PC Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2013/1/3:13:22:40 Kaiser KAISER-PC Rollback Autodesk Material Library 2013 Succeeded
2013/1/3:13:22:40 Kaiser KAISER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/1/3:13:22:40 Kaiser KAISER-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/3:13:22:41 Kaiser KAISER-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/3:13:22:41 Kaiser KAISER-PC Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/3:13:22:41 Kaiser KAISER-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/3:13:22:43 Kaiser KAISER-PC PageOpen InstallCompleteDialog
2013/1/3:13:29:05 Kaiser KAISER-PC === Setup ended ===
2013/1/3:13:54:39 Kaiser KAISER-PC === Setup started on KAISER-PC by Kaiser ===
2013/1/3:13:54:39 Kaiser KAISER-PC Launch
2013/1/3:13:54:39 Kaiser KAISER-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/Autodesk_3ds_Max_2013_EFGJKS_Win_32-64b..." /SN 900-35758403 /PK 128E1 /student /skipEULA /akamai /auth /sid
2013/1/3:13:55:07 Kaiser KAISER-PC === Setup ended ===
2013/1/3:21:45:30 Kaiser KAISER-PC === Setup started on KAISER-PC by Kaiser ===
2013/1/3:21:45:30 Kaiser KAISER-PC Launch
2013/1/3:21:45:30 Kaiser KAISER-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/Autodesk_3ds_Max_2013_EFGJKS_Win_32-64b..." /SN 900-35758403 /PK 128E1 /student /skipEULA /akamai /auth /sid
2013/1/3:21:45:58 Kaiser KAISER-PC === Setup ended ===
2013/1/3:21:45:32 Kaiser KAISER-PC === Setup started on KAISER-PC by Kaiser ===
2013/1/3:21:45:32 Kaiser KAISER-PC Launch
2013/1/3:21:45:57 Kaiser KAISER-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:21:45:58 Kaiser KAISER-PC PageOpen LaunchDialog
2013/1/3:21:46:27 Kaiser KAISER-PC PageOpen LicenseDialog
2013/1/3:21:46:27 Kaiser KAISER-PC PageOpen ProductSelectionDialog2
2013/1/3:21:46:32 Kaiser KAISER-PC PageOpen LicenseDialog
2013/1/3:21:46:32 Kaiser KAISER-PC PageOpen LaunchDialog
2013/1/3:21:48:26 Kaiser KAISER-PC PageOpen LicenseDialog
2013/1/3:21:48:26 Kaiser KAISER-PC PageOpen ProductInfoDialog
2013/1/3:21:48:26 Kaiser KAISER-PC PageOpen ProductSelectionDialog2
2013/1/3:21:49:22 Kaiser KAISER-PC PageOpen FullProgressDialog
2013/1/3:21:49:23 Kaiser KAISER-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:21:49:23 Kaiser KAISER-PC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/3:21:52:22 Kaiser KAISER-PC Install DirectX® Runtime Succeeded
2013/1/3:21:52:26 Kaiser KAISER-PC PageOpen InstallCompleteDialog
2013/1/3:21:52:32 Kaiser KAISER-PC === Setup ended ===
2013/1/3:21:52:51 Kaiser KAISER-PC === Setup started on KAISER-PC by Kaiser ===
2013/1/3:21:52:51 Kaiser KAISER-PC Launch
2013/1/3:21:52:51 Kaiser KAISER-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/Autodesk_3ds_Max_2013_EFGJKS_Win_32-64b..." /SN 900-35758403 /PK 128E1 /student /skipEULA /akamai /auth /sid
2013/1/3:21:52:59 Kaiser KAISER-PC === Setup ended ===
2013/1/3:21:52:53 Kaiser KAISER-PC === Setup started on KAISER-PC by Kaiser ===
2013/1/3:21:52:53 Kaiser KAISER-PC Launch
2013/1/3:21:52:58 Kaiser KAISER-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:21:52:59 Kaiser KAISER-PC PageOpen LaunchDialog
2013/1/3:21:54:58 Kaiser KAISER-PC PageOpen LicenseDialog
2013/1/3:21:54:58 Kaiser KAISER-PC PageOpen ProductInfoDialog
2013/1/3:21:54:58 Kaiser KAISER-PC PageOpen ProductSelectionDialog2
2013/1/3:21:55:14 Kaiser KAISER-PC PageOpen FullProgressDialog
2013/1/3:21:55:15 Kaiser KAISER-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:21:55:16 Kaiser KAISER-PC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/3:21:57:19 Kaiser KAISER-PC Install DirectX® Runtime Succeeded
2013/1/3:21:57:21 Kaiser KAISER-PC Download Play CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:21:57:27 Kaiser KAISER-PC Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:21:58:08 Kaiser KAISER-PC Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:21:58:39 Kaiser KAISER-PC Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:22:00:47 Kaiser KAISER-PC Download Error CMILM2013 Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:22:00:48 Kaiser KAISER-PC Download Aborted CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/1/3:22:00:48 Kaiser KAISER-PC Install Autodesk Material Library 2013 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2013/1/3:22:00:48 Kaiser KAISER-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
0 REPLIES 0
Administrator Productivity
