Repeated failure to load AutoCAD onto 32-bit laptop running Windows 7. Other faculty (and students) in department have encountered the same problem. If this is common issue, can it not be fixed? In the meantime what can I do to successfully load the software? Attached is the Install Log documenting two separate attempts. Thank you.
