Installation & Licensing
Download and Install Previous Revit Version
1 REPLY 1
585 Views, 1 Reply
I am having trouble installing a previous version of 2011 Revit Architecture and Structure after sucessfully downloading and installing 2011 Revit MEP.
After the download when I try to install I get error warnings of corrupt files saying I should download fresh copy.
When I try to install I get these error codes:
CRC failed in Revit Setup\ Revit Architecture\ x64.cab
CRC failed in Revit Setup\ Architecture\ x86.cab
I have a newer version of Windows 7, when I installed the 2011 Revit MEP in compatibility with older version of window xp service pack 2. The MEP version actuallys says 2011 Revit B MEP, I do not know what the B means but do not see the same thing in the Architeture and Structure Downloads.
I downloaded the Revit Architecture a second time with the same problem.
Should I request a CD through the subsciption center? Not sure how to move forward on this.
1 REPLY 1
TravisNave
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
