jspayne wrote:
> We currently have two offices running AutoCAD with FlexLM. Each office is pulling licenses from
> their respective servers. However when we have an overflow situation in one office and unused
> licenses in the other FlexLM won't go and get the licenses from the other office. I have
> modified the licpath.lic file on the client computers to read: SERVER "servername1" SERVER
> "servername2" USE_SERVER
> The servers are on the same network. The first server indicated is the only one that FlexLM will
> use. I can have users in location 1 pull licenses from location 2 by putting the servername for
> location 2 first in his licpath.lic file. However it won't automatically pull from the second
> location if the first is out of licenses.
Unfortunately you cannot use LICPATH.LIC with distributed servers, you need to use the
ADSKFLEX_LICENSE_FILE environment variable as described in the following solution:
http://support.autodesk.com/getdoc.asp?id=TS64909
Mark Taylor
Product Support, EMEA
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
