Installation & Licensing
Display problem Autodesk 3ds Max 2011 32-bit
5 REPLIES 5
shihabsharia
1326 Views, 5 Replies
while i working with any project a certain location of project hang like picture 1.picture 1
This part omitted untill fully close Autodesk 3ds Max 2011. as Picture 2
My os windows 8 , 64 bit, 4 gb ram. internal display, motherboard:MS-7816, Processor: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz (4 CPUs), ~3.2GHz
Please help me for this issue.
Shihab
Shihab.sharia@gmail.com
picture 2
Tags (3)
5 REPLIES 5
TravisNave
in reply to: shihabsharia
This is graphic artifacting.  You need to make sure you are running a supported graphics card with the latest WHQL certified graphics driver.  Since you did not list your video card, I cannot recommend a specific driver.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
shihabsharia
in reply to: TravisNave
Thanks for your quick reply. No external cards. My graphic details as below:
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_78161462&REV_06
Display Memory: 1755 MB
Dedicated Memory: 32 MB
Shared Memory: 1723 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: DELL E1910H
Monitor Model: DELL E1910H
Monitor Id: DELD023
Native Mode: 1366 x 768(p) (59.790Hz)
Output Type: HD15
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3345 (English)
Driver Version: 10.18.10.3345
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread
Driver Attributes: Final Retail
Driver Date/Size: 10/28/2013 14:06:34, 12151296 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-C37A-1C58BBC2C735}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x78161462
Revision ID: 0x0006
Driver Strong Name: oem6.inf:5f63e534dd898f5e:iHSWD_w8:10.18.10.3345:pci\ven_8086&dev_0412
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
TravisNave
Yeah, if all you have is an onboard Intel graphics card, then that's not
going to cut it. You need to get an approved graphics card for that
program or just deal with the artifacting. Sorry.
Autodesk Forums:
shihabsharia
Ok I need a card. Another thing, My windows running 64 bit and 3ds max running 32 bit. Does it may any problem for any issue?
TravisNave
That is unlikely. 32-bit cannot usually be installed on 64-bit. But if
that is the case, then yes you should install the correct version.
Autodesk Forums:
Administrator Productivity
