I am attempting an install of Revit Architectur Suite from disk. The AutodCAD and Architecture disks installed just fine. However, when I attempt to install Revit, I get the following error message:
Error 1305. Error reading from file D:\x64\RAC2012\ProgramFiles\Autodesk\Root\Program\DGNPro.dll. Verify that the file exists and that you can access it.
What should I do?
try copying the disc to your harddrive and installing from there
DarrenP
I did copy the set of DVDs to a network drive, each in a separate subfolder.
All of the programs installed perfectly EXCEPT for Revit. What is the solution to this problem?
