I am wondering if there is any way that Autodesk 360 can be disabled for Revit LT 2014. With the AutoCAD install, I know that in the setup.ini file you can remove the ADSYNC from POSTREQUISITE, and it wont install with the functionality, but I don't seem to be able to find anything similar to this, or any settings that would perform this same function. It is against the security policy of the company I work for to be able to sync with the cloud with applications, and I am automating this install.
http://upandready.typepad.com/up_and_ready/2013/05/security-and-installing-autodesk-360.html
and...
http://usa.autodesk.com/getdoc/id=TS14863102
The TS above, I have done and it completely removed access in AutoCAD. Please let me know if it works in Revit as well.
So during install there is nothing about 360, that first option doesn't work. I can turn InfoCenterOn to 0 in the registry, but it doesn't seem to prevent me from logging into 360. It turns off any information coming into the communications center, but that is it.
