Installation & Licensing
directx runtime failure on AutoCad 2014
5 REPLIES 5
6847 Views, 5 Replies
trying to install autocad 2014 LT onto my windows 7 computer.  I had a trial version of 2013 on it and now want to upgrade and purchase it - but it isn't loading.
I looked at a few other of similar cases, but they seemed to be from earlier versions of autocad...
AND GOD KNOWS, THERE ISN'T A FRICKING PHONE NUMBER TO CALL AUTOCAD!!!
Here is the log file that was saved:
2013/7/24:08:24:02 bk BK-BAZINGA === Setup started on BK-BAZINGA by bk ===
2013/7/24:08:24:02 bk BK-BAZINGA Path_Length: 152
2013/7/24:08:24:02 bk BK-BAZINGA Current Directory C:\Autodesk\AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us
2013/7/24:08:24:02 bk BK-BAZINGA Launch
2013/7/24:08:24:02 bk BK-BAZINGA CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/AutoCADLT_2014_SWL_English_Win_32_64bit_wi_en-us_... /akamai /auth authparam /sid SESSION_ID
2013/7/24:08:24:02 bk BK-BAZINGA Current Directory C:\Users\bk\AppData\Local\Temp\_AI4397.tmp
2013/7/24:08:24:51 bk BK-BAZINGA === Setup ended ===
2013/7/24:08:24:05 bk BK-BAZINGA === Setup started on BK-BAZINGA by bk ===
2013/7/24:08:24:05 bk BK-BAZINGA Path_Length: 152
2013/7/24:08:24:05 bk BK-BAZINGA Current Directory C:\Users\bk\AppData\Local\Temp\_AI4397.tmp
2013/7/24:08:24:05 bk BK-BAZINGA Launch
2013/7/24:08:24:32 bk BK-BAZINGA Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/SETUP_x64....
2013/7/24:08:24:51 bk BK-BAZINGA Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/SETUP_x64....
2013/7/24:08:24:51 bk BK-BAZINGA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\bk\AppData\Local\Temp\_AI4397.tmp\Setup\AcSetup.dll
2013/7/24:08:24:51 bk BK-BAZINGA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/24:08:24:51 bk BK-BAZINGA PageOpen LaunchDialog
2013/7/24:08:27:42 bk BK-BAZINGA PageOpen LicenseDialog
2013/7/24:08:27:45 bk BK-BAZINGA PageOpen ProductInfoDialog
2013/7/24:08:27:49 bk BK-BAZINGA PageOpen ProductSelectionDialog2
2013/7/24:08:27:51 bk BK-BAZINGA PageOpen FullProgressDialog
2013/7/24:08:27:52 bk BK-BAZINGA Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/DIRECTX.ta...
2013/7/24:08:27:56 bk BK-BAZINGA Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/DIRECTX.ta...
2013/7/24:08:27:56 bk BK-BAZINGA Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD LT 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/24:08:29:26 bk BK-BAZINGA Install DirectX Runtime Succeeded
2013/7/24:08:29:26 bk BK-BAZINGA Download Play CM http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CM.tar.lzm...
2013/7/24:08:29:45 bk BK-BAZINGA Download Complete CM http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CM.tar.lzm...
2013/7/24:08:29:45 bk BK-BAZINGA Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/24:08:30:21 bk BK-BAZINGA Install Autodesk Material Library 2014 Succeeded
2013/7/24:08:30:22 bk BK-BAZINGA Download Play CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CMILB.tar....
2013/7/24:08:30:41 bk BK-BAZINGA Download Complete CMILB http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/CMILB.tar....
2013/7/24:08:30:41 bk BK-BAZINGA Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® LT 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD LT 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/24:08:31:08 bk BK-BAZINGA Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/24:08:31:09 bk BK-BAZINGA Download Play ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2013/7/24:08:32:36 bk BK-BAZINGA Download Aborted ACADLT http://trial2.autodesk.com/SWDLDNET3/2014/ACDLT/WI/{DD86A595-6C57-42A2-874F-C81BDF5A0EFA}/ACADLT_x64...
2013/7/24:08:32:36 bk BK-BAZINGA Install Autodesk® AutoCAD LT® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/24:08:32:41 bk BK-BAZINGA Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/24:08:33:14 bk BK-BAZINGA Rollback Autodesk Material Library 2014 Succeeded
2013/7/24:08:33:14 bk BK-BAZINGA Rollback DirectX Runtime Failed Failure is ignored, Result=1619
so Autocad - if you want me to spend my money - get this program installed on my computer!!!!
5 REPLIES 5
TravisNave
Welcome to the Community.
I understand your frustration, but the problem does not exist within the DirectX installation, but rather a problem downloading the software from the server.
I would recommend that you try downloading your product using Matt, the virtual assistant, by following the directions here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
As for telephone support, that is a service provided by your local Value Added Reseller.  If product support is important to you, then you should always purchased your software from a VAR rather than a big box / Internet store.
Good Luck!
Autodesk Forums:
in reply to: TravisNave
I was going to buy it directly from Autodesk....is that not the best strategy?
TravisNave
There is no harm in doing so.  However, if you desire product support beyond the purchase, that is what the VARs are for.
Autodesk Forums:
I am getting the exact same problem but when I click on your link it takes me to a help page but I can't find this virtual assistant?
pendean
Administrator Productivity
