Hello everyone,
Today I'm trying to install 3ds max but keep running into a problem that I can't resolve. I searched across the vast internet and haven't found anything that helps.
After installation, 3ds Max tells me that the installation has failed and to view the log to find the problem. Everything seems to install correct until I see the problem: Rollback DirectX® Runtime UpdateFailedFailure is ignored, Result=1619
I can't seem to find the solution to this problem, I would really like some help as soon as possible.
Thanks.
Welcome to the Community!
Install Autodesk 3ds Max 2011 32-bit Failed Installation aborted, Result=1603
That is where your problem exists. Do you have the larger install log in your %TEMP% folder? Also, what is your OS? This version of Max is not supported on Win8, just in case you are trying that.
Thank you for replying Travis!
I currently do not have a larger version in my Temp folder however I do have 3ds Max 2012 log file when i tried installing that version instead (still same problem),and my current OS is Windows 7 64-bit.
It appears your %TEMP% folder might be on D:\. Do you have enough room on D:\?
In that temp location, you should still have another installation log that is larger. It should contain more information to the reason for your 1603 failure.
You might consider clearing out that folder then reinstalling. Should make the file easier to find. Heck, clearing temps sometimes actually allows the program to install. Might be worth a shot.
Hey Travis, sorry it took so long for a reply but i was able to find the file. Didn't expect it to be named Max Installation. However, I can't put the fiel in the attachments because it is currently too big. Have an alternative?
Zip it.
