Installation & Licensing
DirectX Runtime Failed Failure is ignored, Result=1619
1 REPLY 1
alam25
1442 Views, 1 Reply
HI,
Ive tried several times to install AutoCad 2015 but the installation fails every time, while installing the DirectX Runtime. THank you in advance
2014/10/17:13:59:42 Alamdar ALM-PC === Setup started on ALM-PC by Alamdar ===
2014/10/17:13:59:42 Alamdar ALM-PC Path_Length: 157
2014/10/17:13:59:42 Alamdar ALM-PC Current Directory C:\Autodesk\AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us
2014/10/17:13:59:42 Alamdar ALM-PC Launch
2014/10/17:13:59:42 Alamdar ALM-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/AutoCAD_2015_English_Win_32_64bit_Trial_wi_en-us_Se... /akamai /trialMode /skipEULA /auth authparam /sid Trial1413572346495
2014/10/17:13:59:42 Alamdar ALM-PC Current Directory C:\Users\Alamdar\AppData\Local\Temp\_AID2B.tmp
2014/10/17:14:00:36 Alamdar ALM-PC === Setup ended ===
2014/10/17:13:59:45 Alamdar ALM-PC === Setup started on ALM-PC by Alamdar ===
2014/10/17:13:59:45 Alamdar ALM-PC Path_Length: 157
2014/10/17:13:59:45 Alamdar ALM-PC Current Directory C:\Users\Alamdar\AppData\Local\Temp\_AID2B.tmp
2014/10/17:13:59:45 Alamdar ALM-PC Launch
2014/10/17:13:59:45 Alamdar ALM-PC Download Play SETUPMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKER_...
2014/10/17:13:59:46 Alamdar ALM-PC Download Complete SETUPMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUPMARKER_...
2014/10/17:13:59:46 Alamdar ALM-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.ta...
2014/10/17:14:00:36 Alamdar ALM-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/SETUP_x64.ta...
2014/10/17:14:00:36 Alamdar ALM-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Alamdar\AppData\Local\Temp\_AID2B.tmp\Setup\AcSetup.dll
2014/10/17:14:00:36 Alamdar ALM-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/10/17:14:00:36 Alamdar ALM-PC PageOpen LaunchDialog
2014/10/17:14:00:40 Alamdar ALM-PC PageOpen LicenseDialog
2014/10/17:14:00:40 Alamdar ALM-PC PageOpen ProductInfoDialog
2014/10/17:14:00:40 Alamdar ALM-PC PageOpen ProductSelectionDialog2
2014/10/17:14:01:14 Alamdar ALM-PC PageOpen FullProgressDialog
2014/10/17:14:01:15 Alamdar ALM-PC Download Play STARTMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKER_...
2014/10/17:14:01:15 Alamdar ALM-PC Download Complete STARTMARKER http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/STARTMARKER_...
2014/10/17:14:01:15 Alamdar ALM-PC Download Play VCREDIST2012X86UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/17:14:01:18 Alamdar ALM-PC Download Complete VCREDIST2012X86UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/17:14:01:18 Alamdar ALM-PC Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Alamdar\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2014/10/17:14:01:20 Alamdar ALM-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2014/10/17:14:01:20 Alamdar ALM-PC Download Play VCREDIST2012X64UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/17:14:01:24 Alamdar ALM-PC Download Complete VCREDIST2012X64UPD4 http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/VCREDIST2012...
2014/10/17:14:01:24 Alamdar ALM-PC Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Alamdar\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2014/10/17:14:01:25 Alamdar ALM-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2014/10/17:14:01:25 Alamdar ALM-PC Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.tar....
2014/10/17:14:01:33 Alamdar ALM-PC Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/DIRECTX.tar....
2014/10/17:14:01:33 Alamdar ALM-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2015\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/17:14:01:46 Alamdar ALM-PC Install DirectX Runtime Succeeded
2014/10/17:14:01:46 Alamdar ALM-PC Download Play CM http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzma2
2014/10/17:14:02:08 Alamdar ALM-PC Download Complete CM http://trial2.autodesk.com/SWDLDNET4/2015/ACD/WI/{ECEFBCAC-BCD2-4AEA-AC1D-A41F223301DE}/CM.tar.lzma2
2014/10/17:14:02:08 Alamdar ALM-PC Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2015" SETUP_PACKAGECODE={E5C1CEF2-523C-456E-B0A7-DE574483ACD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/17:14:02:08 Alamdar ALM-PC Install Autodesk Material Library 2015 Failed Installation aborted, Result=2
2014/10/17:14:02:09 Alamdar ALM-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2014/10/17:14:02:09 Alamdar ALM-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2014/10/17:14:02:09 Alamdar ALM-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
1 REPLY 1
dembkod
in reply to: alam25
alam25
Uninstall the Visual C++ entries on the system and then uninstall NET. You are in conflict with C++ and possibly NET on this system.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
