Installation & Licensing
DirectX® Runtime Failed Failure is ignored, Result=1619
34 REPLIES 34
Message 1 of 35
92648 Views, 34 Replies
I'm trying to run a fresh install, (Win7 x64) network version and continue to get the message that .net 4.0 is not installed.
I checked windows updates and it's listed, along with installing from MS site .net 4.0 to which it gives me the option ot repair or remove, I repair and that finishes.
I've rebooted the pc and started to install autocad 2012 again, with the same message and end result of failed install and this failure in the log
Any help is appreciated.
34 REPLIES 34
Message 2 of 35
here is the entire log:
2012/12/18:08:25:51 jweber CTS166-PC === Setup started on CTS166-PC by jweber === 2012/12/18:08:25:51 jweber CTS166-PC Launch 2012/12/18:08:27:44 jweber CTS166-PC PageOpen LaunchDialog   2012/12/18:08:27:59 jweber CTS166-PC PageOpen LicenseDialog   2012/12/18:08:28:02 jweber CTS166-PC PageOpen ProductInfoDialog   2012/12/18:08:28:32 jweber CTS166-PC PageOpen ProductSelectionDialog2   2012/12/18:08:29:17 jweber CTS166-PC PageOpen FullProgressDialog   2012/12/18:08:29:17 jweber CTS166-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q 2012/12/18:08:29:39 jweber CTS166-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded  2012/12/18:08:29:39 jweber CTS166-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): D:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q 2012/12/18:08:29:59 jweber CTS166-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded  2012/12/18:08:29:59 jweber CTS166-PC Installing DirectX® Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent 2012/12/18:08:30:45 jweber CTS166-PC Install DirectX® Runtime Succeeded  2012/12/18:08:30:45 jweber CTS166-PC Installing FaroSDK:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/18:08:31:27 jweber CTS166-PC Install FaroSDK Succeeded  2012/12/18:08:31:29 jweber CTS166-PC Installing Autodesk® Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\jweber\AppData\Local\Temp\_AI91B4.tmp\Media.mst"
 2012/12/18:08:31:54 jweber CTS166-PC Install Autodesk® Material Library 2012 Succeeded  2012/12/18:08:31:55 jweber CTS166-PC Installing Autodesk® Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\jweber\AppData\Local\Temp\_AI91B4.tmp\Media.mst"
 2012/12/18:08:32:21 jweber CTS166-PC Install Autodesk® Material Library 2012 - Low Resolution Succeeded  2012/12/18:08:32:21 jweber CTS166-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): D:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\jweber\AppData\Local\Temp\vcredist_x86_2005.log"" " 2012/12/18:08:32:45 jweber CTS166-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded  2012/12/18:08:32:45 jweber CTS166-PC Installing Autodesk® Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/18:08:33:05 jweber CTS166-PC Install Autodesk® Content Service Succeeded  2012/12/18:08:33:05 jweber CTS166-PC Installing AutoCAD® Electrical 2012:  TRANSFORMS="D:\x64\en-us\acade\acad.mst;C:\Users\jweber\AppData\Local\Temp\_AI91B4.tmp\x64\acade\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" INSTALLDIR="C:\Program Files\Autodesk\Acade 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/12/18:08:36:48 jweber CTS166-PC Install AutoCAD® Electrical 2012 Failed Installation aborted, Result=1603 2012/12/18:08:37:30 jweber CTS166-PC Rollback Autodesk® Content Service Succeeded  2012/12/18:08:37:30 jweber CTS166-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619 2012/12/18:08:38:15 jweber CTS166-PC Rollback Autodesk® Material Library 2012 - Low Resolution Succeeded  2012/12/18:08:38:39 jweber CTS166-PC Rollback Autodesk® Material Library 2012 Succeeded  2012/12/18:08:38:45 jweber CTS166-PC Rollback FaroSDK Succeeded  2012/12/18:08:38:45 jweber CTS166-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619 2012/12/18:08:38:48 jweber CTS166-PC PageOpen InstallCompleteDialog   2012/12/18:08:40:01 jweber CTS166-PC === Setup ended ===
Message 3 of 35
Darin.Green
ctsautocad,
The correct error message you're getting is 1603 with AutoCAD Electrical according to the error log you posted.
Looking through the rest of the log, it appears you're having an issue with Ngen. To resolve this issue do the following:
You will need the following application to resolve this issue:
ORCA (program allows you to modify an MSI file)
Orca Download
If you have a thumb drive or DVD, you will need to copy the contents onto your hard drive.
  1. Navigate to the location of the installation files
  2. Navigate to the x64 folder
  3. Find the application folder:
    • INSTALLFILES\X64\Acade
    • Right-Click the acad.msi file and choose “Edit with Orca”
Once Orca is opened, navigate to the “CustomAction” table
Notice on the right side panel under Action, there are a number of action items. Select each of the following items and right-click and choose “Drop Row”
  • InstallPreJit
  • NgenCreate
  • NgenCreateRollback
  • NgenDelete
  • NgenDeleteRollback
  • UninstallPreJit
Go to File > Save. Than close the Orca application.
Install AutoCAD Electrical.
If this information was helpful, please consider using the Accept Solution
Tags (1)
Message 4 of 35
in reply to: Darin.Green
Darin,
I know this is an old post, but thought I'd reply anyway in hopes of an explanation.  I've looked through the log file posted and cannot find any reference to ngen.  Can you explain how you were able to come to this conclusion?
Message 5 of 35
Darin.Green
Hi Brandon,
I vaguely remember the steps I took to figure this out, but it literally took me over 5 hours of looking through logs, event viewer, and online research. I do product support for a reseller “Synergis Engineering Design Solutions” and we encounter hundreds of cases relating to the roll back issues with AutoCAD Arch, MEP, Mechanical, and Electrical which I decided to dedicated almost an entire day to finding a solution. One of the main causes of those issues stemmed from the new way AutoCAD vertical applications are now installed—For example, If AutoCAD 2013 is already installed, and now you install AutoCAD Architecture, it will not install another instance of AutoCAD as it did in the past but instead install the missing components in a sub directory of the AutoCAD.
Some of this information as well as another issue relating to NGEN.exe, use the following link:
http://upandready.typepad.com/up_and_ready/2012/10/error-ngenexe-and-installing-any-autocad-product....
I know I didn’t fully answer your question, but I can’t remember exactly what lead me to that solution.
[cid:image1bcfc7.GIF@7b461ca9.4ab0c189]
Darin Green
Product Support Specialist
472 California Road | Quakertown, PA 18951
Main Office: 800-836-5440
Direct Dial: 215-302-3000
Fax: 215-302-3001
www.synergis.com
Blog | Facebook | Twitter | LinkedIn | YouTube
Synergis Achieves Platinum Status, Autodesk’s Highest Tier for VARs
This email and any attachments are intended only for the person or entity to which it is addressed and may contain information which is confidential, privileged or otherwise protected from disclosure. Distribution or copying of this email or the information contained herein by anyone other than the intended recipient is prohibited. If you have received this email in error, please immediately notify the sender by return email and please delete and destroy this email and any attachments.
Message 6 of 35
can someone help me to solve this problem. i try to reinstall revit 2012. but it say " installation complete, but some product failed to install"  here the installation log. please response as soon as posiible. i need it to do my school project.
Message 7 of 35
Darin,
I figured there was more involved in determining the cause that wasn't obvious by looking at the log file exclusively.
Thanks for the explanation.
Brandon
Message 8 of 35
Hi Im having this issue...all seems to go okay in log until this point...I was trying to 'install now' and am wondering if I cannot fix this manually will Autodesk will let me re downoad another format such as "download now" instead. Can anyone talk me through how to resolve this particular issue as most threads seem to focus on different errors messages and codes? I am using windows * on a new laptop and am struggling wnough with new interface and have pressing project for uni toget getting on with ;( I have provided the complete log file...I think?
2014/5/24:01:04:01 Nadine NADS Download Error CMILM <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2014/5/24:01:04:01 Nadine NADS Download Error CMILM Decompressing failed http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2014/5/24:01:04:01 Nadine NADS Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/CMILM...
2014/5/24:01:04:01 Nadine NADS Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/5/24:01:04:12 Nadine NADS Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/5/24:01:04:37 Nadine NADS Rollback Autodesk® Material Library 2014 Succeeded
2014/5/24:01:04:37 Nadine NADS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/5/24:01:04:37 Nadine NADS Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/5/24:01:04:37 Nadine NADS Rollback Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/5/24:01:04:37 Nadine NADS Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/5/24:01:04:38 Nadine NADS PageOpen InstallCompleteDialog
2014/5/24:01:15:53 Nadine NADS === Setup ended ===
Message 9 of 35
sorry just realised this is autocad issues and mines is 3d max....hope someone has an idea or two anyway but sorry for posting in wrong section
Message 10 of 35
The link doesn't work.
Message 11 of 35
Darin.Green
Here you go:
http://www.technipages.com/download-orca-msi-editor
Message 12 of 35
same problem, however i dont have the files, i am downloading them and installing directly from autodesk website . this is such a pain! things were more simple before
2016/5/10:16:58:50 Pablo DESKTOP-BPP1914 Path_Length: 155
2016/5/10:16:58:50 Pablo DESKTOP-BPP1914 Current Directory C:\Users\Pablo\AppData\Local\Temp\_AIE603.tmp
2016/5/10:16:59:29 Pablo DESKTOP-BPP1914 === Setup ended ===
2016/5/10:17:00:00 Pablo DESKTOP-BPP1914 === Setup started on DESKTOP-BPP1914 by Pablo ===
2016/5/10:17:00:00 Pablo DESKTOP-BPP1914 Path_Length: 155
2016/5/10:17:00:00 Pablo DESKTOP-BPP1914 Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2016/5/10:17:00:00 Pablo DESKTOP-BPP1914 Launch
2016/5/10:17:00:00 Pablo DESKTOP-BPP1914 CommandLine /PK 001F1 /SN 900-71693146 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-us_Setup....
2016/5/10:17:00:00 Pablo DESKTOP-BPP1914 Current Directory C:\Users\Pablo\AppData\Local\Temp\_AIF88D.tmp
2016/5/10:17:00:27 Pablo DESKTOP-BPP1914 === Setup ended ===
2016/5/10:17:00:04 Pablo DESKTOP-BPP1914 === Setup started on DESKTOP-BPP1914 by Pablo ===
2016/5/10:17:00:04 Pablo DESKTOP-BPP1914 Path_Length: 155
2016/5/10:17:00:04 Pablo DESKTOP-BPP1914 Current Directory C:\Users\Pablo\AppData\Local\Temp\_AIF88D.tmp
2016/5/10:17:00:04 Pablo DESKTOP-BPP1914 Launch
2016/5/10:17:00:05 Pablo DESKTOP-BPP1914 Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2016/5/10:17:00:27 Pablo DESKTOP-BPP1914 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SETUP_x64....
2016/5/10:17:00:27 Pablo DESKTOP-BPP1914 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\Pablo\AppData\Local\Temp\_AIF88D.tmp\Setup\AcSetup.dll
2016/5/10:17:00:27 Pablo DESKTOP-BPP1914 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/5/10:17:00:28 Pablo DESKTOP-BPP1914 PageOpen LaunchDialog
2016/5/10:17:00:39 Pablo DESKTOP-BPP1914 PageOpen LicenseDialog
2016/5/10:17:00:39 Pablo DESKTOP-BPP1914 PageOpen ProductInfoDialog
2016/5/10:17:00:39 Pablo DESKTOP-BPP1914 PageOpen ProductSelectionDialog2
2016/5/10:17:00:44 Pablo DESKTOP-BPP1914 PageOpen FullProgressDialog
2016/5/10:17:00:44 Pablo DESKTOP-BPP1914 Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.ta...
2016/5/10:17:00:49 Pablo DESKTOP-BPP1914 Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DIRECTX.ta...
2016/5/10:17:00:49 Pablo DESKTOP-BPP1914 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2016/5/10:17:01:16 Pablo DESKTOP-BPP1914 Install DirectX Runtime Succeeded
2016/5/10:17:01:16 Pablo DESKTOP-BPP1914 Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/5/10:17:01:41 Pablo DESKTOP-BPP1914 Install FARO LS 5.1.0.30630 (64bit) Succeeded
2016/5/10:17:01:41 Pablo DESKTOP-BPP1914 Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2016/5/10:17:01:55 Pablo DESKTOP-BPP1914 Download Aborted CM http://edutrial.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM.tar.lzm...
2016/5/10:17:01:55 Pablo DESKTOP-BPP1914 Install Autodesk Material Library 2014 Failed Download Failed, Installation aborted, Result=1603
2016/5/10:17:01:58 Pablo DESKTOP-BPP1914 Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2016/5/10:17:01:58 Pablo DESKTOP-BPP1914 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Message 13 of 35
Darin.Green
You're using the Install Now Option, instead Download the software from here then install:
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Message 14 of 35
PLEASE! PLEASE!! PLEASE!!! CAN YOU URGENTLY HELP AND BAIL ME OUT. ALL I SIMPLY WANT TO DO IS TO DOWNLOAD A FREE 30-DAYS TRIAL VERSION OF AutoCAD 2017 LT, AND PLAN TO PURCHASE IT THEREAFTER. AND I'VE BEEN TRYING TO DOWNLOAD AND INSTALL FOR THE PAST 3 DAYS
BUT
the following  error log has been shown!!!!! IT SHOULDN'T BE GIVING SLEEPLESS NIGHTS DOING THIS..
ERROR LOG [in the attachment]
AOO
Message 15 of 35
TravisNave
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Autodesk Forums:
Message 16 of 35
Hi Brandon, can you help me. I want to install Autocad Architecture 2017 from website but it stops. I have tried to reinstall my microsoft visual c++ but it didn't work. The installation stops as always.
I hope it will be solved soon. Thank you.
2016/9/16:21:16:53 AsusPC DESKTOP-U07ICJG === Setup started on DESKTOP-U07ICJG by AsusPC ===
2016/9/16:21:16:53 AsusPC DESKTOP-U07ICJG Path_Length: 162
2016/9/16:21:16:53 AsusPC DESKTOP-U07ICJG Current Directory C:\Users\AsusPC\AppData\Local\Temp\_AI2D8E.tmp
2016/9/16:21:16:53 AsusPC DESKTOP-U07ICJG Launch
2016/9/16:21:16:55 AsusPC DESKTOP-U07ICJG Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/SETU...
2016/9/16:21:16:55 AsusPC DESKTOP-U07ICJG Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/SETU...
2016/9/16:21:16:55 AsusPC DESKTOP-U07ICJG Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\AsusPC\AppData\Local\Temp\_AI2D8E.tmp\Setup\AcSetup.dll
2016/9/16:21:16:55 AsusPC DESKTOP-U07ICJG Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/9/16:21:16:55 AsusPC DESKTOP-U07ICJG PageOpen LaunchDialog
2016/9/16:21:17:20 AsusPC DESKTOP-U07ICJG PageOpen LicenseDialog
2016/9/16:21:17:20 AsusPC DESKTOP-U07ICJG PageOpen ProductInfoDialog
2016/9/16:21:17:20 AsusPC DESKTOP-U07ICJG PageOpen ProductSelectionDialog2
2016/9/16:21:19:24 AsusPC DESKTOP-U07ICJG PageOpen FullProgressDialog
2016/9/16:21:19:25 AsusPC DESKTOP-U07ICJG Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/STAR...
2016/9/16:21:19:25 AsusPC DESKTOP-U07ICJG Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/STAR...
2016/9/16:21:19:25 AsusPC DESKTOP-U07ICJG Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/UCRT...
2016/9/16:21:19:25 AsusPC DESKTOP-U07ICJG Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/9/16:21:19:25 AsusPC DESKTOP-U07ICJG Install Universal C Runtime (KB3118401) Succeeded
2016/9/16:21:19:25 AsusPC DESKTOP-U07ICJG Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/VCRE...
2016/9/16:21:19:25 AsusPC DESKTOP-U07ICJG Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\AsusPC\AppData\Local\Temp\vcredist_x86_2015.log
2016/9/16:21:19:26 AsusPC DESKTOP-U07ICJG Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/9/16:21:19:26 AsusPC DESKTOP-U07ICJG Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/VCRE...
2016/9/16:21:19:26 AsusPC DESKTOP-U07ICJG Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\AsusPC\AppData\Local\Temp\vcredist_x64_2015.log
2016/9/16:21:19:26 AsusPC DESKTOP-U07ICJG Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/9/16:21:19:26 AsusPC DESKTOP-U07ICJG Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/DIRE...
2016/9/16:21:19:26 AsusPC DESKTOP-U07ICJG Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/9/16:21:19:33 AsusPC DESKTOP-U07ICJG Install DirectX Runtime Succeeded
2016/9/16:21:19:33 AsusPC DESKTOP-U07ICJG Download Skipped CM http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/CM.t...
2016/9/16:21:19:33 AsusPC DESKTOP-U07ICJG Installing Autodesk Material Library 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® Architecture 2017" SETUP_PACKAGECODE={28B89EEF-0004-0000-0002-CF3F3A09B77D} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={3BF3E650-3A19-4632-B2C7-AFAD99BD7DCC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD Architecture 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/9/16:21:19:50 AsusPC DESKTOP-U07ICJG Install Autodesk Material Library 2017 Succeeded
2016/9/16:21:19:51 AsusPC DESKTOP-U07ICJG Download Play CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/CMIL...
2016/9/16:21:22:33 AsusPC DESKTOP-U07ICJG Download Aborted CMILB http://edutrial.autodesk.com/NET17SWDLD/2017/ARCHDESK/WI/{9E5C6653-F4DE-47C4-9A18-AFFE6BE36BB0}/CMIL...
2016/9/16:21:22:33 AsusPC DESKTOP-U07ICJG Install Autodesk Material Library 2017 - Base Image Library Failed Download Failed, Installation aborted, Result=1603
2016/9/16:21:22:47 AsusPC DESKTOP-U07ICJG Rollback Autodesk Material Library 2017 Succeeded
2016/9/16:21:22:47 AsusPC DESKTOP-U07ICJG Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/9/16:21:22:47 AsusPC DESKTOP-U07ICJG Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/9/16:21:22:47 AsusPC DESKTOP-U07ICJG Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Message 17 of 35
Mark.Lancaster
@Anonymous
Welcome to the community...
Your issue has nothing to do with C++..  Its failing due to the method you are using..
Download and install per:
1. Access the Autodesk Virtual Agent (http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk&startContext=Root.Front%20Desk) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
Message 18 of 35
in reply to: Mark.Lancaster
Wow! Thanks to God, Thanks to you also. It works. Thank you so much for your help. May God bless you Mark.
Message 19 of 35
Hi all,
I have been trying to install Autodesk Architecture 2016 for a week now.
I have run through many attempts (following advice from this community) to completely remove Autodesk from my PC.
Even after removing everything I can find including registry values andusing the virtual assistant links I still get the message
"Autocad 2016 is not on this computer it must be installed"
this happens when I try to install AutoCad or Autodesk Architecture
I would love to get this sorted out and hopefully you good folks can help out
if it's not to presumptuous I have attached my install log
Message 20 of 35
Mark.Lancaster
@Anonymous
Sorry that you got this problem..  1603 failure on a core Autodesk product..  Not good.  Smiley Sad
See @TravisNave and my information in this posting.   Some users have had success in reinstalling Windows but that's not really a viable solution.  Another thing you may want to do is to download and install AutoCAD first to see if you can get it installed by itself.
If something does work for you please let us know because to this date no one has indicated any success in getting over the 1603 error on a core product install.
Mark Lancaster
Administrator Productivity
