Installation & Licensing
Direct Connect 2014 install error when installing 3ds Max 2014
1 REPLY 1
DMCMachine
2150 Views, 1 Reply
Hi, I just finished installing 3ds Max Student edtion and it installed everything but Direct Connect 2014, I tried to install it again but this message keeps popping up and it wont go away if i press retry.  The image below are of the message itself and the text is of the installation log.
2013/11/16:11:50:20 Joshua THEGRID Installing Autodesk® DirectConnect 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/16:11:53:36 Joshua THEGRID Install Autodesk® DirectConnect 2014 Failed Failure is ignored, Result=1603
1 REPLY 1
david.lau
in reply to: DMCMachine
I would try to use a browser download of the software because the download maybe corrupt.
http://forums.autodesk.com/t5/Inventor-General/Autodesk-Inventor-wont-install-error-1308/m-p/3890032...
Please review steps 1 & 3 here:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
David Lau
Administrator Productivity
