My problem is that all the icons of autocad are too small on my screen i think it is because of my high resolution screen.
as you can see in the image the command bar is really big but the icon in the bottom of the sccreen are almost unseeable.
It looks like your computer windows settings. Change the resolution and the Display Settings. One of these is likely connected.
Right-click Desktop, click “Personalize”
Click “Display” on the bottom left.
Adjust these size settings and see if it helps.
Thank you for taking part in our community!
Thanks for answering so quickly.
this answer didn't lead to a solution if i put this size to 500%
everything zooms in only the icons stay small
Great finally it's solved
i now use 100% and 2048*1152 instead of 3480*2160
