Installation & Licensing
Desktop icons refresh a dozen or more times when AutoCAD Civil 3D is loading
2 REPLIES 2
coopdetat
200 Views, 2 Replies
Hi again,
My desktop icons refresh a dozen or more times when AutoCAD Civil 3D is loading.  The flashing and blinking is a nuisance that I would like to eliminate if at all possible.  I do not see this behavior when loading any other program.
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 10 Pro 64-bit Intel﴾R﴿ Core﴾TM﴿ i9-12900KF CPU 3.19GHz; 32 GB DDR4 4266 Dual Channel RAM
nVidia Quadro RTX 4000; AutoCAD Civil 3D 2023.2.1 Update
2 REPLIES 2
TravisNave
in reply to: coopdetat
Autodesk products are more graphically intensive than other programs such as Word.  My suggestion would be to make sure:
1.  You are using a certified video card
2.  You are using a certified video driver for said card
3.  You are running at the recommended screen resolution for your product
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
coopdetat
in reply to: TravisNave
1. check
2. check
3. check
Administrator Productivity
