Installation & Licensing
Design Suite Premium 2014 installation error
2 REPLIES 2
280 Views, 2 Replies
I am trying to install the Design Suite 2014 on one of my work's windows 7 machines. during the initialization process it shows the error that it cannot open drive or file c:\users\admini~1\local\appdata\temp.. and then some other folder info. The main issue I see is that I do not have any user profile by the name of Admini~1 so such a folder does not exist. Is there a reason that the Program needs to open this particular file? or is it a formated issue in the setup files looking for the wrong host?
2 REPLIES 2
TravisNave
Welcome to the community.
That location is simply the 8.3 path location for the %TEMP% folder in the Administrator account.  That being said, I have to assume you are installing as Administrator or that your program was already installed as Administrator.  In any case, clear the contects of that folder and then reinstall ensuring that you are indeed a local administrator, UAC is off, and your anti-virus temporarily disabled (especially if Trend Micro.)
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Thank you Very Much. I had forgotten that Trend Micro was the Aniti-virus Used by my company Thank you Very Much
Administrator Productivity
