i am having problems downloading dessign review 2013. when the download completes and i run the install runs and says. " the following failed to install: autodesk design review 2013 (0x2:Failed downloading component" i need to open this file from my customer. there is something wrong witht he download link for trueview convert autodesk told me and no i dont know what to do. i have also tried opening it in autodesk360 but there is a problem opening the file it says
Greetings! You will try the solutions from this thread and let me know if that resolves your issue? Please also take these steps before your next download attempt:
Please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer or let me know if you continue to experience problems. Thank you!
