When installing Inventor after creating a deployment file we recieve this error in the log-
2010/10/27:18:05:47 admin VHS807A === Setup started on VHS807A by admin ===
2010/10/27:18:08:48 admin VHS807A Install .NET Framework 2.0 SP2 Update KB958481 Succeeded
2010/10/27:18:09:32 admin VHS807A Install .NET Framework 3.0 SP2 Update KB958483 Succeeded
2010/10/27:18:09:54 admin VHS807A Install .NET Framework 3.5 SP1 Update KB958484 Succeeded
2010/10/27:18:10:30 admin VHS807A Install DirectX 9.0 Runtime Succeeded
2010/10/27:18:17:40 admin VHS807A Install DWG TrueView 2011 Succeeded Reboot is required
2010/10/27:18:17:52 admin VHS807A Install Microsoft Chart Controls Succeeded
2010/10/27:18:20:29 admin VHS807A Install Autodesk Material Library 2011 Succeeded
2010/10/27:18:22:55 admin VHS807A Install Autodesk Material Library 2011 Base Image library Succeeded
2010/10/27:18:41:57 admin VHS807A Install Autodesk Inventor 2011 Failed Installation aborted, Result=1603
2010/10/27:18:42:07 admin VHS807A Install Setup You must restart your system for the configuration changes to take effect. Click Yes to restart now or No if you plan to manually restart later.
2010/10/27:18:42:19 admin VHS807A === Setup ended ===
Thank you in advanced.
Can you provide more detail? Set the deployment so that it is not silent and upload screen shots of any errors displayed. Also upload the Inventor2011Install.log form the temp folder. You can find it in the temp folder by typing %TEMP% in the Address bar of Windows Explorer.
Try these common 1603 solutions:
1. Microsoft Installer documentation lists that the 1603 indicates a resource needed by the installer is in use by another process. Often a reboot will stop this. Quitting background applications during the installation of an application is a best practice.
2. Bad media, dirty lens, bad optical drive or bad optical drive drivers can all cause this. If you downloaded the 2010 or 2011 product and it extracted to the C:\Autodesk (or your designated) folder. This should not be the case. You can restart the installer from the Setup.exe without need to re-extract the installer from the download. If you are trying to install from the DVD copy the contents to a temp folder on the local hard drive. If there are several disks start with the first disk then copy additional disks, in order, into the same location and overwrite any files if asked.
3. Permissions are sometimes associated with this error. For Windows Vista and Windows 7 try disabling UAC. Make sure you are a Local Administrator. Sometimes a Domain Admin needs to be added to the local Administrators group. Right-clicking the setup.exe and choosing to Run as Administrator may be necessary as well.
