Installation & Licensing
philip.s
Message 11 of 24 (4,570 Views)
Re: Deployment of DWG TrueView 2013 on Windows 7 x64
10-18-2012 04:17 PM in reply to: cadmgr
Sorry for the extended wait everyone, but hopefully it's worth it / here you go!
DWG TrueView 2013 32BIT
DWG TrueView 2013 64BIT
Philip Schmelzer
Active Contributor
justforthispost
Message 12 of 24 (4,536 Views)
10-23-2012 05:17 AM in reply to: philip.s
I'm sorry to report I'm still getting the same error when deploying the x64 version as discribed in the opening post.
Active Contributor
justforthispost
Message 13 of 24 (4,497 Views)
10-29-2012 02:51 AM in reply to: philip.s
Anyone still working on this Philip?
Active Contributor
justforthispost
Message 14 of 24 (4,366 Views)
12-04-2012 12:44 AM in reply to: philip.s
Still no fix for this Autodesk?
Member
AlphatronAdmin
Message 15 of 24 (4,334 Views)
12-05-2012 05:37 AM in reply to: justforthispost
Deploying a batchfile through GPO works for me.
[code]
if exist "%programfiles%\Autodesk\DWG TrueView 2013\dwgviewr.exe" goto eof
start /wait "\\ServerName\Software\AutoCAD Viewer\2013\x64\setup.exe" /q /w /t "\\ServerName\Software\AutoCAD Viewer\2013\x64\setup.ini"
:eof
exit
[/code]
Good luck.
Active Contributor
justforthispost
Message 16 of 24 (4,327 Views)
12-06-2012 12:57 AM in reply to: philip.s
Ofcourse it will work if I run a bat file wich calls the exe. But then you are missing the whole point of deploying the msi to a workstation.
Does anyone of autodesk still reads this topic?
Member
AlphatronAdmin
Message 17 of 24 (4,320 Views)
12-06-2012 01:31 AM in reply to: justforthispost
Well, Autodesk doesn't respond that much (eg. http://forums.autodesk.com/t5/Installation-Licensing/msi-in-GPO-not-working-quot-Run-Setup-exe-to-in...).
For some dark, mysterious reason, it's impossiple to push the msi directly from your GPO without problems (eg. Computer>Policies>Software Settings>Assigned Applications>dwgviewr.msi with or without transform file), so you might as well give up trying & whining, apply a workaround, do the exotic deployment and focus to your end goal: Trueview deployment.
I've rewritten my batch, with a little improvement.
[code]
:: check for previous installations
if exist "%programfiles%\Autodesk\DWG TrueView 2012\dwgviewr.exe" goto 2012
:2012
:: remove 2012
msiexec /qn /norestart /x "ServerName\Software\AutoCAD Viewer\2012\x64\x64\dwgviewr\dwgviewr.msi"
:: setup 2013
msiexec /qn /norestart /i "ServerName\Software\AutoCAD Viewer\2013\x64\x64\dwgviewr\dwgviewr.msi"
:eof
exit
[/code]
Good luck.
Active Contributor
justforthispost
Message 18 of 24 (4,310 Views)
12-06-2012 07:05 AM in reply to: philip.s
Thanks for your input. However I do hope someone of Autodesk will read this and will reply :smileyhappy:
cadmgr
Message 19 of 24 (4,295 Views)
12-06-2012 10:26 AM in reply to: justforthispost
As a staunch supporter of PLEASE HIRE MORE MODERATORS to participate in Autodesk discussion groups, I'll  acknowledge here that the new exe appears to work for 64-bit W7.
Good luck with the GPO.
New Member
vulkoek
Message 20 of 24 (3,966 Views)
03-01-2013 06:02 AM in reply to: justforthispost
This problem still issn't fixed. Is there anyone from Autodesk that can help me with this ?
