1. Adding search paths: only one new path is allowed if you use the browse button. Workaround: Manually enter paths (PIA)
2. Express tools not installed. Admin image has express tools folder. Support request in progress.
3. Program option settings unavailable. For the last deployment I was able to set options like: What version acad saves files to, duration between autosaves, color scheme, show true silouettes...solids, enable grips within blocks, etc, etc,
Anyone else have any issues creating a deployment?
Using 64 bit Windows 7
When I create a deployment for AutoCad 2012 it appears to be fine. However, when I try to run it from a workstation it just runs and runs, literally for days, before it ultimately restarts the computer. When I log into the computer, Autocad is not installed. What can be causing this?
