I have to create deployments for IDSP, BDSP, BDSS. Is there a way to have all my custom paths populate to all instalations? Example BDSP has several coponents that I have to configure the same custom paths for each. 3 suites with 6 components gets alittle numbing if ya know what I mean.
Your Name
Your Name
Solved by TravisNave. Go to Solution.
Add it to the wish-list Joe. Also add adding additional installations to a deployment from other suites to the wish list. It's all a pipe dream right now my man. If you're creative, you might be able to just change the installation scripts accordingly, but it's still the same work regardless, I guess.
Your Name
Your Name
