I created a network licensed deployment sucesfully with no errors. When I try to run the install using the source the deployment created I get the following 1309 error. I have even tried this using a local drive instead of a network resource. The error is coming up because the HelpHtml folder was not created by the deployment creation. I have created a deployment for Civil 3d 2011 and AutoCad Maps 2008, 2009 and have never ran into this problem. Any suggestions would be apreciated. Thanks.
There are instructions in the AutoCAD Map 3D 2010 Readme and this Technical Solution for copying this HelpHTML folder into a Custom Deployment. The error you are getting is not specifically associated with this error but you should copy these as a first thing to try especially as you have indicated this folder is not in the Deployment.
hi,
i have also faced the same error. i have copied the Helphtlm folder into custom deployment but i could not be fully copied. please give solution if any. snap shot attached
After copied the helphtml folder into custom deployment(admin image) we can able to utilize Autocadmap 11. your suggestion helped us. thanks
But i have another query about the same. I got the error popup on FARO.LS 1.1.406.58 during the installation. after click the OK button it continues and complete the installation. Then the Autocad map11 working. my query is due to the installation error on FARO.LS if any problem or error will comes while using the autocadmap11.
error popup message snap shot attached for reference. Suggestions expected.
