Installation & Licensing
Deployment and AutoCAD Trusted Locations
2 REPLIES 2
Simon_Weel
664 Views, 2 Replies
Now I created a deployment for AutoCAD 2015. And I want to specify Trusted Locations. When entering 'path\...' (backslash and three dots) all sub-folders are considered safe as well. But I can't enter them backslash-three-dots in the deployment configuration? Is there a trick to get them in? Or do I have to specify every location with support files? Simon
2 REPLIES 2
TravisNave
in reply to: Simon_Weel
What is the problem that you are experiencing?  If the deployment is on your domain with appropriate rights, then what is the issue?
Autodesk Forums:
Simon_Weel
in reply to: TravisNave
Never mind, I solved it by just adding several trusted paths in the deployment. Simon
Administrator Productivity
