We have 7 licenses for each the Autodesk Building Design Suite Premium 2012, 1 Ultimate license as well as 2 for Autocad Revit MEP 2012. We are only interested in installing the Revit software on 6 systems right now. I have created a deployment on the network using the Revit MEP 2012 download and have activated both licenses. Is it possible to use this same deployment for the other 4 and modify the serial number (and key) to activate the Revit software? It seems like a lot of work to request permission for each, download each version of software and create a deployment for each package when using just the same portion (only Revit MEP) of the software. Thanks
Unlikely as the other suites are probably not set up to recognize the product key. You could modify the deployment and see if it accepts it with green checkmarks. If so, you might just come out lucky.
