Installation & Licensing
Deploying AutoCAD 2013 silently
7 REPLIES 7
Message 1 of 8
523 Views, 7 Replies
Hi
I'm trying to deploy AutoCAD using SCCM to many computers and am having problems finding any kind of help online.
First, I need to know where I can learn about setup.exe switches and their use. I can't seem to find a list of switches anywhere.
Second I need to know if I can somehow use a pre created deployment to do this or maybe I should just install right off the original setup files.
Thanks.
7 REPLIES 7
Message 2 of 8
ukdxb012
All this is taken care for you now by Autodesk 🙂
If you create a Deployment Image of AutoCAD 2013, you should notice in the location of the Network where you saved your Deployment Image that there is a folder called "SMS_SCCM scripts"... in here you should find the following information.
.\AdminImage\setup.exe /W /q /I AdminImage\AutoCAD 2013 x64.ini /language en-us
If you want to learn about switches then look up the type of installer but add on switches in the search on Google and you should pull up some useful info...
I always use Deployment Images as a starting point, append Service PAcks to the Deployment Images and then bolt on anything else at the backend of the install using the switch /qb so when installing its silent but you at least see something happening 🙂
Hope that helps!
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 3 of 8
in reply to: ukdxb012
I'll give it a try and let you know how it went.
Message 4 of 8
ukdxb012
How did you get on?
Duncan Brannan
Twitter | LinkedIn
Message 5 of 8
Did what you said and everything seemed to go well except it's not grabbing our license server info. I thouhgt it would since I put the info in when I created the deployment but it seems not.
We use a Single Server License with our serial # ofcourse.
Since it didn't work automatically with the deployment I'm guessing it's possible to put this info in through the command line I'm using? Right now I tried the default one which is .\AdminImage\SETUP.EXE /W /q /I AdminImage\RMI.ini /language en-US
If I could get the correct syntax to do this it's would be great.
Itzik
Message 6 of 8
ukdxb012
Did you enter any Server details in the Deployment Image itself? We use the ADSKFLEX_LICENSE_FILE Environment System Variable to point the users to our license servers. Generally we push this variable out via Group Policy.
Duncan Brannan
Twitter | LinkedIn
Message 7 of 8
Yep that did it. All is working even with SP1.
Thanks for the help.
Itzik
Message 8 of 8
ukdxb012
Glad it all worked in the end! Don't forget Kudos 🙂
Duncan Brannan
Twitter | LinkedIn
Administrator Productivity
