Hi
I'm trying to deploy AutoCAD using SCCM to many computers and am having problems finding any kind of help online.
First, I need to know where I can learn about setup.exe switches and their use. I can't seem to find a list of switches anywhere.
Second I need to know if I can somehow use a pre created deployment to do this or maybe I should just install right off the original setup files.
Thanks.
Solved by ukdxb012. Go to Solution.
All this is taken care for you now by Autodesk 🙂
If you create a Deployment Image of AutoCAD 2013, you should notice in the location of the Network where you saved your Deployment Image that there is a folder called "SMS_SCCM scripts"... in here you should find the following information.
.\AdminImage\setup.exe /W /q /I AdminImage\AutoCAD 2013 x64.ini /language en-us
If you want to learn about switches then look up the type of installer but add on switches in the search on Google and you should pull up some useful info...
I always use Deployment Images as a starting point, append Service PAcks to the Deployment Images and then bolt on anything else at the backend of the install using the switch /qb so when installing its silent but you at least see something happening 🙂
Hope that helps!
Did what you said and everything seemed to go well except it's not grabbing our license server info. I thouhgt it would since I put the info in when I created the deployment but it seems not.
We use a Single Server License with our serial # ofcourse.
Since it didn't work automatically with the deployment I'm guessing it's possible to put this info in through the command line I'm using? Right now I tried the default one which is .\AdminImage\SETUP.EXE /W /q /I AdminImage\RMI.ini /language en-US
If I could get the correct syntax to do this it's would be great.
Itzik
