Installation & Licensing
Default template file invalid
4 REPLIES 4
4597 Views, 4 Replies
Hi all
Just loaded revit Architecture 2011 and are getting a message when it is opened saying:
The default template file you have specified does not exist.
C:ProgramData/Autodesk/RAC2011/MetricTemplates/default AUSENU.rte
Can someone please tell me what I need to do to fix this. I do recall seeing a message about a problem when I was loading the program but don't recall the problem.  Do I need to do a reinstall? It would much appreciated.
Cam
4 REPLIES 4
vivekramesh
in reply to: 00113777
Run a search for the AUSENU.rte on your machine and copy it onto the same path.
Else, you can search for it from your DVD Media and copy and paste it again on the same path.
Vivek Ramesh
Product Support Specialist
Global Services
Autodesk, Inc.
an74612
I am having the same problem.  All in all, "6 of 6 content bundles could not be installed and were skipped."  The response to the first question does not really help me.  I m not sure of how to run a search for files.  This is a very frustrating problem and I am wondering what caused this?
vivekramesh
in reply to: an74612
In case you find searches difficult try run a "Repair" of the application.
In order ti do this you seed to go to Start?Control Panel/Add/Remove Programs/<Product Name>/Change or Remove
Here choose the "Repair" option.
Vivek Ramesh
Global Services
Autodesk, Inc.
lopesn3339
in reply to: vivekramesh
I am installing from a deployment that was created and it seems like the content files/folder was not included in the installation. Is there a way to include it in the deployment?
Administrator Productivity
