Hi all
Just loaded revit Architecture 2011 and are getting a message when it is opened saying:
The default template file you have specified does not exist.
C:ProgramData/Autodesk/RAC2011/MetricTemplates/default AUSENU.rte
Can someone please tell me what I need to do to fix this. I do recall seeing a message about a problem when I was loading the program but don't recall the problem. Do I need to do a reinstall? It would much appreciated.
Cam
Run a search for the AUSENU.rte on your machine and copy it onto the same path.
Else, you can search for it from your DVD Media and copy and paste it again on the same path.
I am having the same problem. All in all, "6 of 6 content bundles could not be installed and were skipped." The response to the first question does not really help me. I m not sure of how to run a search for files. This is a very frustrating problem and I am wondering what caused this?
In case you find searches difficult try run a "Repair" of the application.
In order ti do this you seed to go to Start?Control Panel/Add/Remove Programs/<Product Name>/Change or Remove
Here choose the "Repair" option.
