Installation & Licensing
Message 1 of 9
germyw68
236 Views, 8 Replies
CUI Help!!
I just received a new computer from my company and was transferring data from the old to the new. I am by no means a "tech-guru" but was wanting my previous set-up for use on the new computer. I am needing help in getting my CUI file correct.
8 REPLIES 8
Message 2 of 9
TravisNave
in reply to: germyw68
CUI and CUILOAD from the command line should get you the dialog boxes you need to export and then load your CUI files.
You can start here:
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/documentation/ACD/2013/ENU/files/GU...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 9
germyw68
in reply to: TravisNave
Thanks for the help. I have managed to get myself in further trouble by deleting the cui files I made while failing at my attempts at importing the one from my previous computer....
Message 4 of 9
TravisNave
Are they still on the old computer?
Autodesk Forums:
Message 5 of 9
germyw68
I copied them to a disc yesterday so that I could set up my laptop last night for use today. Not working out to well for me so far...
Message 6 of 9
TravisNave
CUILOAD should put them into place, unless you named them acad.cui...
Autodesk Forums:
Message 7 of 9
germyw68
I tried that earlier and unfortunately it brings in SOME of the info, but turns all the icons into clouds. Not understanding that part. Thanks for your help again!
Message 8 of 9
germyw68
Also, it does not bring in my workspaces or anything
Message 9 of 9
TravisNave
You can go into each one and change its cloud into the right one. Probably
pointed in the wrong place for the icon itself. Used to be a very common
problem when moving CUI files. You can search AutoCAD Cloud Icons all
day...
http://forums.autodesk.com/t5/AutoCAD-Electrical-General/Ribbon-icons-all-turned-to-question-mark-cl...
Autodesk Forums:
Administrator Productivity
