I just received a new computer from my company and was transferring data from the old to the new. I am by no means a "tech-guru" but was wanting my previous set-up for use on the new computer. I am needing help in getting my CUI file correct.
CUI and CUILOAD from the command line should get you the dialog boxes you need to export and then load your CUI files.
You can start here:
Thanks for the help. I have managed to get myself in further trouble by deleting the cui files I made while failing at my attempts at importing the one from my previous computer....
I copied them to a disc yesterday so that I could set up my laptop last night for use today. Not working out to well for me so far...
CUILOAD should put them into place, unless you named them acad.cui...
I tried that earlier and unfortunately it brings in SOME of the info, but turns all the icons into clouds. Not understanding that part. Thanks for your help again!
