Installation & Licensing
Cross Vertical product licensing
2 REPLIES 2
203 Views, 2 Replies
I have several floating seats of Civil and Map that are not being used.  I need addational seats of AutoCAD, is it possible to draw from that seat pool when I run out of AutoCAD licenses?
Steven LaKose
2 REPLIES 2
TravisNave
If it is network licensing, the cascading should work automagically.  What versions and what licensing scheme are you using?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
They are all 2011 licenses.
Seems due to that they are seperate packages, (AutoCAD, Civil and Map) I don’t think they will automatically cascade.
It's been bumped up to the Autodesk support team and I forwarded them some licensing info.
I'm hopedful that they may be able to adjust the license file.
Steve
Administrator Productivity
